Power to coil
Old Mar 30, 2008 | 05:06 AM
GrnZ's Avatar
Default Power to coil
Im getting no spark , i just replaced my coil and i tested my icm and its good. I have power at both the - and + terminals on the coil. Why am i not getting any spark?
Old Mar 30, 2008 | 05:27 AM
GrnZ's Avatar
Also after reading about timing , and how turning the dizzy retards and advances timing. Where should i tighten the bolts for the dizzy at? center, more clockwise / counter clockwise?
Would this affect the car not getting spark?
Old Mar 30, 2008 | 05:37 AM
goodtrouble's Avatar
Default Re: (GrnZ)
I think center is stock, and I don't think this will affect the car getting spark or not. But did you have a bad dizzy? Sometimes changing the coil doesn't solve the problem. A friend of mine had a DA where he switched every component inside the dizzy and it still didn't work. Then he decided to buy a new dizzy and it worked fine.
Old Mar 30, 2008 | 05:52 AM
GrnZ's Avatar
The car wont start , after putting the new coil in the cranking seems as if it is more high pitched now. Im really fed up with this car, i have no idea why i have power to the coil at the + and - terminals and cant get any spark !?!?!?!
Old Mar 30, 2008 | 07:16 AM
GrnZ's Avatar
no one can ever answer my question if the + and - terminals on the coil are supposed to have power.......
hey man
Dec 22, 2010 06:59 AM
x19trix72x
Sep 30, 2008 04:43 PM
ChilBlu92
Dec 28, 2006 06:35 PM
Steve90HB
Apr 2, 2004 10:52 PM
10seceg
Jan 26, 2004 08:54 AM
