Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow + OEM ITR Springs Height Clarification ????
Old Mar 29, 2008 | 11:12 PM
EL-Driver's Avatar
Default Koni Yellow + OEM ITR Springs Height Clarification ????
Helping out my cousin and I have been out of the Honda Game for 5-years...
none the less, looking at how a Koni Yellow + OEM ITR Springs would look on his 99 Integra GSR
The Koni Yellow he is looking to use is going to be the Koni Yellow Neuspeed Edition
and set the perch to the lowest setting....
now from what I remember from 5 years ago the ITR Springs are about a 1 inch drop front and rear..
and if I match it with the Koni Yellow's, at the lowest perch the total drop should be 2" all around
am I correct or will the height be higher then that?
thank you for your help
Old Apr 1, 2008 | 07:00 AM
AltimaXX's Avatar
Default Re: Koni Yellow + OEM ITR Springs Height Clarification ???? (EL-Driver)
Bump, I've been wondering this too. I think it should be around 1.5", maybe a little more.
Old Apr 2, 2008 | 04:25 AM
aznlaoboi315's Avatar
wow seriously.... nobody knows anything about this? c'mon guys, I saw a thread on this topic with tons of pics. I too need to know about this setup and would appreciate it if someone can steer us in the right direction.
BUMP somebody help
Old Apr 3, 2008 | 12:33 AM
XANTHODC2R's Avatar
Default Re: Koni Yellow + OEM ITR Springs Height Clarification ???? (aznlaoboi315)
Maybe you guys could check Type-R forum
Old Apr 3, 2008 | 12:38 AM
bmoua's Avatar
talk with partrickgsr...if i remember correctly he has stock gsr springs on koni yellows.
Old Apr 17, 2008 | 05:53 PM
Default Re: (bmoua)
i don't know who patrickgsr is... I searched for him on the member list search and nothing...
Old Apr 18, 2008 | 10:20 AM
eksteve's Avatar
Default Re: (aznlaoboi315)
The oem ITR springs will lower your car 10mm (0.4in) when compared to any other integra spring. And they are nice and stiff
Scroll down till you see the Type R paragraph, read up on it!
http://en.wikipedia.org/wiki/Honda_Integra
Old Apr 18, 2008 | 10:57 AM
Default Re: (eksteve)
https://honda-tech.com/zerothread?id=2091317
Murk 'EM
Feb 24, 2011 02:32 PM
chris3k
Feb 4, 2007 06:50 PM
asianalbutt
Jan 6, 2006 05:42 AM
speedevo
Aug 31, 2002 05:13 AM
