Classic Hondas All Pre-1988 Hondas.
Could I put a GSR in a 78 civic?
Old Mar 29, 2008 | 10:33 PM
maxaldinger's Avatar
Default Could I put a GSR in a 78 civic?
is it possible? I know Id need some gnarly motor mounts and would probably have to run with the hood off, but could it be done?
Old Mar 31, 2008 | 10:11 AM
xbabysharkx's Avatar
Default Re: Could I put a GSR in a 78 civic? (maxaldinger)
if you have enough $$$ anything is possible. but get ready to spend.
Old Mar 31, 2008 | 11:37 AM
2DrSE-i's Avatar
yes you can, if your pockets are deep enough. You may want to check dimensions of the engine bay as well. Either way, its gonna be a tight fit.
Old Mar 31, 2008 | 06:03 PM
ChiefRainingStereotype's Avatar
Why would he need deep pockets? If you could weld and wield a sawzall yourself, all you need is half a brain. The only thing I see being a large expenditure outside of the engine/tranny/ecu/wiring harnesses is possibly custom axles, but even thats not a big deal
Old Mar 31, 2008 | 07:38 PM
funkmaster's Avatar
There is a big difference in being able to do something and being able to do it right. To properly swap in an engine with custom mounts a certain degree of engineering knowhow would be required as the position of the drivetrain and its connecting components is crucial to reliable performance.
BadFoxDragon
Apr 1, 2019 05:59 AM
dipillo
May 1, 2005 01:11 PM
rough_draft
Mar 21, 2005 08:43 AM
b18civicdx
Aug 10, 2004 08:46 PM
SystemAddict
20
May 1, 2002 01:46 PM
