Turbo Manifold Question
Does anyone out there know if the RSX turbo manifolds will fit the new Si's? i know the exhaust flange will fit but will there be any firewall clearance issues? TIA!
My Greddy turbo sits on top of the manifold with unequal length runners to make everything fit properly. When I installed the turbo there is quite a bit of clearance. I think the problem would be after fitting the turbo onto the RSX manifold you might have issues with positioning.
I have the Greddy turbo kit. The charge piping wouldn't matter as you can find those easily and can customize it to make it all fit. I'm talking about after you mount the turbo onto the manifold, with the downpipe, you would possibly run into clearance problems with the firewall.
sitinduk
Aug 4, 2011 08:37 AM
roydogg
Jan 21, 2006 03:10 AM
