Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Cam timing
Old Mar 29, 2008 | 06:11 PM
allsho's Avatar
Default Cam timing
Ok i will try to explain this as easy as possible.. i put a new timing belt on my d16y8.. the cam gear has a word "up" punched on it. so at first i figured that shoudl face up.. but on two of the spines on almost opposite sides there is one notch on either side..
There is two arrows on the head to.. Now if i line the notch up to the arrow i can't get the other notch to line up to the other arrow.. and the word "up" is not dirrectly verticle.. so what theh ell do i do?
Old Mar 29, 2008 | 09:18 PM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Default Re: Cam timing (allsho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allsho &raquo;</TD></TR><TR><TD CLASS="quote">Ok i will try to explain this as easy as possible.. i put a new timing belt on my d16y8.. the cam gear has a word "up" punched on it. so at first i figured that shoudl face up.. but on two of the spines on almost opposite sides there is one notch on either side..
There is two arrows on the head to.. Now if i line the notch up to the arrow i can't get the other notch to line up to the other arrow.. and the word "up" is not dirrectly verticle.. so what theh ell do i do?</TD></TR></TABLE>
Wrong forum man.
Old Mar 29, 2008 | 10:12 PM
fo shizzle yo!'s Avatar
* B A N N E D *
ok, well, i am not entirely sure on the d16's but i know "for sure" that on the b16's the cams have that notched on them as well. those notches must be faced toward the center facing (lined up) eachother dead on. if not then your day is gonna suck! this i know caus ei put skunk2 cams on my b16 so i am assuming the stock cam gears on your d16 would be the same. if you already figured it out by now and i am wrong let me know that way i know for future reference
97grnrs
May 10, 2007 03:25 PM
ohsnapzafingcu
May 3, 2006 09:38 PM
mike93eh
Aug 11, 2005 11:20 AM
civickiller
Mar 8, 2004 11:34 AM
sporkcrx
Sep 24, 2002 07:51 PM
