OBD0-OBD1 conversion wiring issue solution.(I have seen others with like symptoms)
Old Mar 29, 2008 | 05:22 PM
hughesl's Avatar
Default OBD0-OBD1 conversion wiring issue solution.(I have seen others with like symptoms)
I just converted to OBD1 and had some problems.
I searched Honda Tech to find the answer, but was not able to get one.
While searching I did find others with similar symptoms.
I figured out what the problem was today so I figured I would post it.
Conversion:
P28 ECU w/Hondata
Frog conversion harness
OBD1 distributor (prewired for OBD0 connector advertised on Hondata site.)
Everything was supposed to be plug and play.
Problem:
After install the car would just crank over and not start.
Eventually the CEL light would come on and the car would start and run amazingly rich. I turned the car off and tried again with the same symptoms.
I checked everything I did and could not solve it. Checked Honda tech, no luck.
Finally I looked at the papers with the Frog harness and noticed they had switched CKP-P with CYP-P and CKP-M with CYP-M. This is done to make the distributor conversion easier, unfortunately that does not work with the distributor that is already converted. I switched the wires back on the conversion harness and the car starts and runs with no problems.
Modified by hughesl at 12:45 PM 3/30/2008
Old Mar 30, 2008 | 07:09 AM
CRX_RED's Avatar
hey bro where are those cables at?? i did a a6/y8 mini me and my car wont crank the only way it cranks is when i use a cable straight from the battery to the starter and it turns on for like 5 seconds then i turns off but wont crank with the key and my lights,taillights,clock,radio,wypers any of that works dont know why bro!!! can you help me bro?? lmk man
thanks
Old Mar 30, 2008 | 10:15 AM
EF9 JAMS!!!'s Avatar
Default Re: (CRX_RED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_RED &raquo;</TD></TR><TR><TD CLASS="quote">hey bro where are those cables at?? i did a a6/y8 mini me and my car wont crank the only way it cranks is when i use a cable straight from the battery to the starter and it turns on for like 5 seconds then i turns off but wont crank with the key and my lights,taillights,clock,radio,wypers any of that works dont know why bro!!! can you help me bro?? lmk man
thanks</TD></TR></TABLE>
sounds like you may have a short somewhere man.
Old Mar 30, 2008 | 10:20 AM
CRX_RED's Avatar
Default Re: (EF9 JAMS!!!)
what u mean?? and how do i fix that bro???
Old May 14, 2008 | 12:27 AM
clockwork675's Avatar
chech the main ground that mounts right by the water neck from the engine harness, if its off, it wont turn and everything else will seem like its working fine
Paul26
24
Oct 14, 2012 01:29 PM
Vtec-CRX
May 2, 2010 05:40 PM
BMWCReXXX89
Sep 5, 2006 06:00 PM
Cprace1
Nov 18, 2005 03:41 PM
91lsteg
Jan 9, 2005 11:43 AM
