will 91 crx function & forms fit on my 95 civic coupe or what mod is needed
Old Mar 29, 2008 | 04:38 PM
nipcup101's Avatar
Default will 91 crx function & forms fit on my 95 civic coupe or what mod is needed
Can i make these fit onto my coupe. I recently had my car in a fire accident but these are still good. Let me know anything plz there the type 2 and only had them for 3weeks on my car before it burned. thanks everyone
Old Mar 29, 2008 | 05:44 PM
nipcup101's Avatar
Default Re: will 91 crx function & forms fit on my 95 civic coupe or what mod is needed (nipcup101)
why view if u aint got nothing to say i need some to help with some advice thanks.
Old Mar 29, 2008 | 06:47 PM
hondamonda's Avatar
believe the only difference is the forks in the front are different bit it should fit, but dont listen to me though
Old Mar 29, 2008 | 08:37 PM
nipcup101's Avatar
Default Re: (hondamonda)
wat about the back im pretty sure front will be fine with a fork change but the rear is my main concern. Thanks for the help
Old Apr 14, 2008 | 10:31 PM
indoe247's Avatar
Default Re: (nipcup101)
the rear will fit... but you'll need itr controll arm... the front will fit with no mod.
Old May 31, 2008 | 12:23 PM
Chyno's Avatar
I have a 91 DX EF and i used integra coilovers on the civic. What I did is change the front forks because the shock from integra were way to big so I use the integra front forks. And for the rear I did a rear disc brakes conversion so I had integra rear lower control arms. it depends what kind of Rear LCA you got because CRX has 2 types the ones that looks like integra type r and the regular one. Go under and find out first for the LCA
Old May 31, 2008 | 04:10 PM
RyanA's Avatar
Default Re: (indoe247)
Incorrect on the rear needing ITR control arm. 1988 was the only year EF CRX that used that style rear shock. 89-91 used the regular "fork" type shock mounting on the bottom. For the fronts, just re use your CRX lower forks because the CRX front shocks are smaller diameter than the EG/EK/DC.
So yes, they will work with very little work.
Ryan
northkai3
Jan 1, 2010 10:36 AM
hyrev20
Aug 2, 2009 08:14 PM
h4z4rdes
Jan 13, 2006 10:44 AM
RevToTheRedline
Audio / Security / Video
Oct 29, 2004 09:12 AM
ilikemyaccord
Apr 27, 2004 07:06 AM
