h23 injectors h22 motor
Old Mar 29, 2008 | 04:22 PM
turbogsr18's Avatar
Default h23 injectors h22 motor
i know that the h22 have higher cc, but would it be safe to drive on if my vtec is disabled? or would i lean out to much.. maybe a dumb question i dont know.
Old Mar 29, 2008 | 04:25 PM
vlang29's Avatar
Default Re: h23 injectors h22 motor (turbogsr18)
won't run worth a crap on an untuned P13..
Old Mar 29, 2008 | 04:30 PM
turbogsr18's Avatar
Default Re: h23 injectors h22 motor (vlang29)
i have a tuned p13... it seems to run quite well actually.
Old Mar 29, 2008 | 04:34 PM
turbogsr18's Avatar
anyone?
Old Mar 29, 2008 | 05:06 PM
98vtec's Avatar
moderator emeritus
no such thing as a tuned p13 unless you know hex coding.
your ecu is not calibrated to run such small injectors and will not run how it should.
Old Mar 29, 2008 | 05:42 PM
turbogsr18's Avatar
Default Re: h23 injectors h22 motor (98vtec)
car seems to run okay
Old Mar 29, 2008 | 05:47 PM
98vtec's Avatar
moderator emeritus
seems is very ambiguous. Unless you have some way of knowing what the engine is doing, seems means you dont have a clue of how its really running.
an engine can run rich and still run fine. So seems does not mean right.
Old Mar 29, 2008 | 05:50 PM
Acidcrakker's Avatar
If you run those injectors in that motor your going to run a lean motor. The End
Old Mar 29, 2008 | 06:00 PM
98vtec's Avatar
moderator emeritus
Default Re: h23 injectors h22 motor (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">If you run those injectors in that motor your going to run a lean motor. The End</TD></TR></TABLE>
not necessarily, but the engine will not run as it should.
he is probably at the limit of injector duty cycle.
tarheelsoldier
Mar 28, 2007 11:44 AM
preludefien
Jan 16, 2007 10:45 AM
evoalf
Jan 24, 2006 04:50 PM
swaytec360
Dec 5, 2004 06:47 PM
ericsson
Mar 25, 2004 08:30 AM
