gsr oil pan
hey i have a gsr block mounted to a b16 tranny and now im bolting up the oil pan, but i was looking at it and there's no where to bolt up the oil pan on the side of the block that connects to the tranny. does the oil pan bolt up to the flywheel cover?
I was under my car (gsr motor) and it looks like if you remove the flywheel cover there should be two bolt holes or maybe studs (i'm not sure). While you have the flywheel cover off look for the two notches in it (on the top), this is where the 2 holes or studs will be.
I cant get a real good look at it, but there is somewhere to bolt that side for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog »</TD></TR><TR><TD CLASS="quote">I was under my car (gsr motor) and it looks like if you remove the flywheel cover there should be two bolt holes or maybe studs (i'm not sure). While you have the flywheel cover off look for the two notches in it (on the top), this is where the 2 holes or studs will be.
I cant get a real good look at it, but there is somewhere to bolt that side for sure. </TD></TR></TABLE>
Yup, just remove the flywheel splash cover and you'll see the "missing" mounting locations.
No, there should be threaded studs / holes that you put the oil pan and the flywheel cover over. The oil pan should be sandwiched between the block and the flywheel cover.
And yes, post a pic for clarity.
The very left side of that should have the rear main seal housing bolted to the block. I hope you have that there. The windage tray should be there it was put there for a reason. If you have it make sure you put it back.
You must be missing the right side cover
here look at this (its #7 and #23 is one of the two studs)http://www.acuraoemparts.com/d...ch=no
your tranny is already installed isnt it?
It think you may have missed that part when putting it back together otherwise you would be seeing some studs or holes.
Modified by grog at 7:31 PM 4/8/2008
It think you may have missed that part when putting it back together otherwise you would be seeing some studs or holes.Modified by grog at 7:31 PM 4/8/2008
JasonST
Oct 2, 2008 11:17 AM
gdrum
Apr 10, 2004 09:28 AM
