starter removal--94 auto accord
Hi everyone. I have a little problem when I try to remove the starter out from my car. There are some electrical connection as I shown in the red circle in the pics. How can I disconnect it to take out the starter? Do I just pull it out or twist it? I have removed the bolts already just need to remove this connection to take out the starter. Please help. Thanks.
one wire should be the starter solenoid wire [black/white stripe] it is just a pull off connection.
The other wire is the battery lead, under a rubber boot.
Unhook the battery negative lead, then peel back that big rubber boot on the starter and there is a 12mm nut holding the battery lead to the starter connection.
GoodEyeSniper
17
Sep 8, 2006 11:31 PM
