broken motor mount bracket bolts
Old Mar 29, 2008 | 08:18 AM
jdmthug's Avatar
Default broken motor mount bracket bolts
alright guys im in a tight spot..the other day i was driving my ls eg hatch to the store and the bolts that hold the driver side motor mount bracket slid out my block and cause the motor to drop just a little bit which also caused my driver side axle to break..fixin the axle is the easy task..now how would i go about fixing those three broken bolts...anybody have any ideas...the only one i could think of tapping and rethreading the hole and put some new bolts in there and call it a day...if this has happened to u plz let me know how u fixed the problem thanks
Old Mar 29, 2008 | 08:37 AM
biggdogg's Avatar
Default Re: broken motor mount bracket bolts (jdmthug)
unbolt ur exhaust, linkage, rear mount bolt and lift the engine up and get a helicoil set. thats all i can tell ya. its ruff but its doable
Old Mar 29, 2008 | 01:23 PM
jdmthug's Avatar
that was going to be my plan of attack...hopefully this will fix the problem
Old Mar 29, 2008 | 01:49 PM
meandino's Avatar
Default Re: (jdmthug)
I toke mine to the machine shop. Hope you can fix by yourself. It cost me $70.
Old May 19, 2008 | 08:16 PM
forsakenriceboy86's Avatar
thats what happen to my gsr motor when i got it(cheap, complete long block)!.. but mine's in the machine shop getting work done now as we speak!..
the dUDes at the machine shop are pretty kOol and their going to laser mine.. so mine's going to be a clean cut job.. mine is gonna have helical in them to!..
someone tried taking out the broken studS(all three) by themself and really made a mess.. (non was successful) cutted and took off some aluminum from the block where the motor mount studs was broken..
so in the end! i would highly recommend you taking it to the professionals, or someone who has done it before.. unless you have experiences but i've been in the automotive industry for about five years now and i still rather have mine done by proS..
Old May 19, 2008 | 08:32 PM
RyanA's Avatar
Default Re: (forsakenriceboy86)
The best thread replacement is, hands down, the Full Torque. http://fulltorque.com/ Lock n Stitch and Full torque are both unbelievable products.
CyberC1ren
Jan 17, 2014 06:16 PM
CALI-HATCHIN310
Oct 1, 2011 05:20 PM
shytdoode
Jun 3, 2009 02:06 AM
2slowgsx
Oct 30, 2007 08:30 AM
