Suspension & Brakes Theory, alignment, spring rates....
Front suspension Binding up
Old Mar 29, 2008 | 07:21 AM
BlackTOY's Avatar
Default Front suspension Binding up
After doing some suspension work to my integra I have noticed a slight problem. I converted it to a 5 lug and was riding on stock ITR springs and struts. I traded my stock ITR springs and struts to my buddy for his tein s-tech springs and stock struts and he threw in some skunk 2 camber kits. When taking my stock springs/struts out, I had a really hard time getting the lower bolt out of the fork(which holds the spring/strut to the lca). It just seems like its binded up. So I swapped the springs and camber kits out, and then I had a hard time getting the new stuff back together. It only happened on the passenger side of my car.
Has anyone had a similar problem with their suspension being binded up like this. I dont think its the upper control arm because I swapped the stock ones out for the skunk 2 ones. Im leaning towards the fact that my LCA or my front sway bar is bent. The car needs an alignment but I really dont think that an alignment would make the suspension hard to work on like this.
Please give me some feedback!!!
Old Mar 29, 2008 | 07:38 AM
slammed_93_hatch's Avatar
Default Re: Front suspension Binding up (BlackTOY)
probably didn't want to come out because the sway bar was keeping some tension on the LCA.
I wouldn't worry about it.
Old Mar 29, 2008 | 07:44 AM
BlackTOY's Avatar
Default Re: Front suspension Binding up (slammed_93_hatch)
Thanks for the info. Anyone else wanna put .02 on it!!
Old Mar 29, 2008 | 11:58 AM
BlackTOY's Avatar
I know there are some suspension freaks out here that would love to chime in on this.
Old Mar 29, 2008 | 02:37 PM
RyanR's Avatar
you already got your answer. if you would have disconnected your swaybar before touching the shocks you wouldn't have had any problems.
Old Mar 29, 2008 | 06:23 PM
BlackTOY's Avatar
Default Re: Front suspension Binding up (RyanR)
Thanks Ryan!!
A_Rotary_Guy
Dec 18, 2007 06:21 PM
huge230
Nov 4, 2006 07:57 AM
Stunna BEN
85
May 14, 2004 11:50 AM
austrian type-R
Apr 28, 2003 08:15 PM
Nuts
Dec 7, 2001 07:45 AM
