oil pan ITR vs GSR/GS/LS
Old Mar 29, 2008 | 05:17 AM
Rishiras's Avatar
Default oil pan ITR vs GSR/GS/LS
Guys,
I need to buy a oilpan for a friend with 96 ITR, does a GS/Ls/GSR mmodel Oilpan fit the same as from the OEm ITR one? to me it seems the same.
Let me know.
Rishi
Old Mar 29, 2008 | 05:23 AM
Comp97GSR's Avatar
Default Re: oil pan ITR vs GSR/GS/LS (Rishiras)
They are all the same. Even a B16 oil pan will work.
Old Mar 29, 2008 | 10:29 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: oil pan ITR vs GSR/GS/LS (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">They are all the same. Even a B16 oil pan will work.</TD></TR></TABLE>
wrong...
for direct replacement you will need an itr pan or a gsr pan (will have p72 stamp on bottom)
Old Mar 29, 2008 | 10:42 AM
Steady R's Avatar
WRONG
only itr oil pans were blessed by the gods of mount fuji
Old Mar 29, 2008 | 01:53 PM
RedR's Avatar
b16 and ls share the same pan and they r different
Old Mar 29, 2008 | 02:25 PM
Comp97GSR's Avatar
Default Re: oil pan ITR vs GSR/GS/LS (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">
wrong...
Will a B16 pan not bolt up and do the job??
Old Mar 29, 2008 | 02:59 PM
EM1 Loi's Avatar
Will a B16 pan not bolt up and do the job?? </TD></TR></TABLE>
b16/b18b/b20b/b20z all share the same pan.
itr/gsr share the same pan. only a P72 stamped pan will work.
Old Mar 29, 2008 | 07:20 PM
Default Re: oil pan ITR vs GSR/GS/LS (EM1 Loi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1 Loi &raquo;</TD></TR><TR><TD CLASS="quote">
itr/gsr share the same pan. only a P72 stamped pan will work.</TD></TR></TABLE>
exactly... ive also heard that if you use the oil pick-up from the same pan *such as b16 pick-up with b16 pan* that it would work
Old Apr 14, 2009 | 06:39 AM
Petah's Avatar
What about the B16B (CTR) oil pan? Will that work?
Old Apr 14, 2009 | 06:49 AM
6's Avatar
You'll need to get a GSR or ITR oil pan only. As previously said, find a pan that has p72 stamped on it or get an aftermarket pan, like Moroso or the like, specifically for an ITR or GSR. Any oil pans for a B18 non C, or B16, will not clear the crank girdle, therefore, will not mount to the bottom of the block.
Old Apr 14, 2009 | 08:54 AM
Petah's Avatar
But I thought the B16B uses a GSR/ITR block and the girdle of a ITR/GSR?
Old Apr 14, 2009 | 07:20 PM
B16B_coupe's Avatar
HRD PKR
my b16b oil pan is stamped p72 on it
Old Apr 15, 2009 | 07:45 AM
RockinaRHard's Avatar
I have a ITR oil pan...
Old Apr 15, 2009 | 09:47 AM
kaj's Avatar
kaj
maybe you have a GSR/ITR oil pan on your b16? hopefully your pickup is reaching far enough..?
i seem to remember trying a B16 pan on a GSR motor and it wouldn't clear.
Old Apr 15, 2009 | 12:42 PM
Petah's Avatar
He has a B16B, aka CTR engine which uses a ITR/GSR block. I will not be surprised if that oil pan is stock.
Old Apr 15, 2009 | 12:54 PM
kaj's Avatar
kaj
that would 'splain it.
95BoostedEJ1
Feb 22, 2009 07:33 AM
ray on boost
Feb 17, 2009 07:56 AM
Hoffy
Apr 22, 2005 04:38 PM
MrHeeltoe
Aug 26, 2004 09:07 AM
Black R
Oct 22, 2003 11:47 AM
