Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
oil change help?
Old Mar 28, 2008 | 09:39 PM
07si_LENA's Avatar
Default oil change help?
I want to learn how change my own oil.. can someone help me step by step for my 07 si?
Old Mar 28, 2008 | 11:56 PM
boostedLSb18's Avatar
Step 1: Open Oil Cap in the engine bay
Step 2: Raise vehicle on lift or floor jack
Step 3: Get under vehicle
Step 4: Locate oil pan, there's a bolt, place container under bolt, the loosen the bolt.
Step 5: Locate oil filter, it's blue if it's OEM, it's on the passenger side near axle
Step 6: Replace filter
Step 7: Check if oil and drained completely, if so, replace oil pan bolt.
Step 8: Stand back up and lower vehicle
Step 9: Pour about 5 qt of oil, I recommend Eneos Synthetic Oil
Step 10: Put Oil cap back on
Step 11: Make sure all bolts and caps are replaced tightly
Step 12: Start car, if no leaks, sit back and relax or go and enjoy the ride.
FYI: there's a step by step in the owner's manual.
Take care.
Old Mar 29, 2008 | 12:30 AM
ju5tchi11in's Avatar
Default Re: (boostedLSb18)
It was a tight squeeze for me to grab the oilfilter... first change I had trouble finding the filter based on the manual diagram. I actually could not get the OEM one off.
Old Mar 29, 2008 | 06:03 AM
07si_LENA's Avatar
thanks ill try that! i'll tell u how it went
Old Mar 29, 2008 | 06:17 AM
pgpbubble's Avatar
Default Re: (07si_LENA)
oil change on 06+ si's =
Old Mar 29, 2008 | 06:22 AM
07si_LENA's Avatar
Default Re: (pgpbubble)
what do you mean its bs? is it do-able for a beginner?
Old Mar 29, 2008 | 08:21 AM
It can be done by a beginner, we all had to start from somewhere. yes the oil filter is hard to reach and undo, but if you a filter removal tool it should help a little bit. You can get one at your local auto parts store. It kinda looks like a jar opener.
Hondas4All
Oct 22, 2009 12:06 PM
tilhasbb
17
Aug 13, 2007 08:17 AM
asgqwaeg
64
May 31, 2006 03:46 AM
Jordans95si
Aug 23, 2005 08:19 AM
hagrid
Nov 18, 2002 09:25 PM
