Curious Problem
Well...I have a Eg hatchback and my sohc motor is leaking coolant all time when I drive it drips drips...on so my problem how do I fix this leak? is it the water pump or any hose? another thing I went to Autozone bought some stuff to cover up a leak didn't cover leak to well...
that cover up stuff is no good and does not work well at all... you need to find out where its leaking from and then replace that part but remember make sure u are replacing the right part dont just assume its the water pump or any hose u gotta go in there and see exactly where its coming from.. its not hard because the coolant is lime green lol so its very easy to spot the leak unlike an oil leak
klion22
May 27, 2008 12:28 PM
JDMTurboCivic11
Sep 15, 2004 09:51 AM
