VSS SWAP??? F22B IACV + EGR
Old Mar 28, 2008 | 06:35 PM
RIZOBIZERT's Avatar
Default VSS SWAP??? F22B IACV + EGR
Hello all. Just did a F22B into a 91 Accord LX auto. I'm using the P39 ECM. The VSS is flashing a code but the speedo works fine. Any thoughts? Would it have something to do with km/h versus mph? Should I use the one from the original Accord trans.? Also getting the EGR code and IACV code. I believe all of these are codes 12,14,17. Well, the EGR is hooked up and all seems well, any thoughts? The IACV is working just fine. The car idles nicely when cold, when it warms up and when ever I put an load on the motor (A/C, power steering, etc.). Have I overlooked something? The car seems to run great and then the CEL comes on after a few minutes of driving. The only thing I don't have hooked up is the Intake Air Bypass. I'm still working on that, but I'm not getting any CEL's for that. Thanks in advance.
Old Mar 29, 2008 | 04:01 PM
oneoffaccord's Avatar
Default Re: VSS SWAP??? F22B IACV + EGR (RIZOBIZERT)
the VSS and EGR plugs are the same. u mightve plugged them in backwards. the VSS wiring is black yellow and orange.
Old Mar 31, 2008 | 03:31 AM
RIZOBIZERT's Avatar
Default Re: VSS SWAP??? F22B IACV + EGR (oneoffaccord)
Thanks, but no. I'm getting the speedo to read, yet I'm still getting a VSS error code.
RickP
Nov 2, 2013 10:22 PM
Atomic646
Dec 16, 2012 08:05 PM
1accord
Jul 13, 2006 04:34 AM
ImprtTunr
Jul 12, 2002 01:47 PM
