am i forgetting anything?? sleeved b16 build
Old Mar 28, 2008 | 03:35 PM
ShortbusEK's Avatar
Default am i forgetting anything?? sleeved b16 build
this will be the first time for completely assembling an engine so im just making sure im not missing anything.. I have the block and ill be ordering the rest prob monday..
84MM AEBS Sleeved & o-ringed B16 block
JE 84MM b16 9.5:1 pistons w/ JE Nitrous/Turbo rings
Cometic MLS headgasket 84MM .051" (to bring me closer to 9:1.. nobody makes 9:1 84MM b16 pistons unless u custom order.. no thanks)
Eagle 4340 Steel H Beam rods with ARP bolts
ACL rod, main and thrust bearings
ARP head and main studs
Z10 Block girdle
99+ ITR oil pump
99+ SI waterpump
seem like im missing anything?
Old Mar 28, 2008 | 09:01 PM
TheShodan's Avatar
Moderator
Default Re: am i forgetting anything?? sleeved b16 build (ShortbusEK)
why did you go to 9.0:1? 9.5 is a great point to boost.
Old Mar 29, 2008 | 07:16 AM
ShortbusEK's Avatar
Default Re: am i forgetting anything?? sleeved b16 build (TheShodan)
with je and 84mm b16 pistons its either 9.5:1 or 8.3:1... my plan was to run 9.5:1 but when I was chatting with the guy who will more than likely be tuning it yesterday.. he said he would feel more comfortable closer to 9:1 tuning the 35r to 30lbs.. not sure why he said that.. not sure how to calc comp..what would using the .051 gasket net me? i have not purchased the head gasket yet so i can always stick with the stock thickness.
Also I have always read mixed things about head gaskets and hondas.. some swear by the cometic gaskets.. and some swear that OEM is the way to go.. ??? i know GE sales reworked (84mm) oem gaskets
Old Mar 29, 2008 | 11:31 AM
Joseph Davis's Avatar
You want cam gears, between decking/milling and that headgasket your engine isn't in mechanical time anymore.
Frankly? I'd have recommended going with a bigger bottom end than B16, but regardless if you crank the boost **** up you'll be very happy.
Old Mar 29, 2008 | 12:26 PM
ShortbusEK's Avatar
Default Re: am i forgetting anything?? sleeved b16 build (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">You want cam gears, between decking/milling and that headgasket your engine isn't in mechanical time anymore.
Frankly? I'd have recommended going with a bigger bottom end than B16, but regardless if you crank the boost **** up you'll be very happy.</TD></TR></TABLE>
yea im going to run with oem thickness... 9.5:1 will be fine... its only gonna see prob 14-18lbs on the reg.. 28-30 for track purposes and ill have race gas in it so.... i dont see detonation being a prob.. i too would have went with a larger bottom end... but the hatch already had the b16 in it when i picked it up so... b16 it is.. at least its a bit bigger (1715cc) with the 84mm bore
battle951sedan
19
Jan 19, 2012 11:52 AM
ArRsX
Apr 3, 2011 11:07 PM
str8race
Jan 12, 2011 04:03 PM
trini_jdm
Aug 9, 2007 06:15 PM
rjay8604
152
Sep 4, 2005 08:00 PM
