Question about the Mase's jdm conversion
Old Mar 28, 2008 | 02:42 PM
latindc2's Avatar
Default Question about the Mase's jdm conversion
Compas im planning on doing the conversion myself but following this link
http://www.maseengineering.com....html
I was looking at my jdm radiator support and i could not locate the three spot weld on the top so my question would i have trouble doing it cuz on the jdm rad support dont have it? i dont think so just wanted to make sure
Mine
Thanks a lot
Old Mar 28, 2008 | 03:16 PM
DrGrEeNtHuMb's Avatar
There are 3 spot welds on the usdm support that u must drill out in order to begin to take off the rad support. Once you take it all the way off like he says, just spot weld or plug weld the jdm rad support in the correct place. The new welds dont have to be in the same exact spots as the usdm spot welds were.
Old Mar 28, 2008 | 05:39 PM
latindc2's Avatar
Default Re: (DrGrEeNtHuMb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrGrEeNtHuMb &raquo;</TD></TR><TR><TD CLASS="quote">There are 3 spot welds on the usdm support that u must drill out in order to begin to take off the rad support. Once you take it all the way off like he says, just spot weld or plug weld the jdm rad support in the correct place. The new welds dont have to be in the same exact spots as the usdm spot welds were.</TD></TR></TABLE>
Thanks i think ill be able to pull it off
Old Mar 28, 2008 | 07:01 PM
ITR.#1446's Avatar
Default Re: (latindc2)
it looks like the end of the jdm rad support were cut with a dremel or something when you take off your usdm support just line it up it may be too short on the sides but maybe not
Old Mar 28, 2008 | 07:35 PM
DiMpL3s's Avatar
Default Re: (ITR.#1446)
Old Mar 28, 2008 | 07:48 PM
latindc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">it looks like the end of the jdm rad support were cut with a dremel or something when you take off your usdm support just line it up it may be too short on the sides but maybe not</TD></TR></TABLE>
yea thats what im afraid of...
Old Mar 28, 2008 | 10:02 PM
Naruto's Avatar
that would suck.....
Old Mar 28, 2008 | 10:34 PM
ITR.#1446's Avatar
Default Re: (Naruto)
try measuring it from end to end then measure the stock support
Old Mar 30, 2008 | 11:49 AM
latindc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">try measuring it from end to end then measure the stock support</TD></TR></TABLE>
yea good advice
trepteg
Oct 4, 2007 11:36 AM
spec:jdm
Jul 1, 2005 01:00 AM
jdmdc2miami
Jan 7, 2005 03:17 PM
Collateral
Dec 22, 2004 09:47 AM
