Suspension & Brakes Theory, alignment, spring rates....
Ground Control sleeves for a 92-00 Civic on 94-01 Integra?
Old Mar 28, 2008 | 12:06 PM
Vagabund07's Avatar
Default Ground Control sleeves for a 92-00 Civic on 94-01 Integra?
I found some GC coilovers for a 92-00 Civic at a good price, p/n 200.64.58 front and 180.64.44 rear. I have KYB AGX shocks, and I was wondering how the ride will be with these coilovers? I'm not going to slam my car, probably just drop it 1.5" and use only for DD/occasional spirited driving. I know the spring rates for the Civic front (325) are lower than those of the Integra (380), but the rear are the same. I was wondering how big of a difference this will make? Is this a sacrifice at all? Should I just skip the cheap Civic GC's and save for GC's specifically for the Integra? Thanks
Old Mar 28, 2008 | 12:11 PM
BlueIntegraBoy's Avatar
Default Re: Ground Control sleeves for a 92-00 Civic on 94-01 Integra? (Vagabund07)
Ride might be a little softer, but it should be fine.
Old Mar 30, 2008 | 03:34 PM
Vagabund07's Avatar
Default Re: Ground Control sleeves for a 92-00 Civic on 94-01 Integra? (BlueIntegraBoy)
Am I looking at any sacrifices by going with the Civic springs? It'll still be stiffer than stock, correct?
Old Mar 30, 2008 | 03:48 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vagabund07 &raquo;</TD></TR><TR><TD CLASS="quote">Am I looking at any sacrifices by going with the Civic springs? It'll still be stiffer than stock, correct?</TD></TR></TABLE>
you should be fine bro, aslong as you dont slam your ride you should be okay. No matter what springs you with the ride quality will be a stiffer than stock.
Old Mar 30, 2008 | 03:49 PM
Targa250R's Avatar
be professional
You probably wouldn't even notice the difference.
For your intended ride height, you'll be fine.
Old Mar 30, 2008 | 03:53 PM
bmoua's Avatar
Default Re: Ground Control sleeves for a 92-00 Civic on 94-01 Integra? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">You probably wouldn't even notice the difference.
For your intended ride height, you'll be fine.</TD></TR></TABLE>
make sure to get a alignment done after you install the your suspension setup.
Old Apr 1, 2008 | 04:48 PM
Vagabund07's Avatar
Default Re: Ground Control sleeves for a 92-00 Civic on 94-01 Integra? (bmoua)
Alright, thanks for the help everybody. Now I just have to hope my LCA bolts aren't seized...
darcane
Suspension & Brakes
12
May 17, 2013 01:19 PM
xMRDR3Wx
Texas -OK -LA (Sales)
Aug 13, 2008 06:57 PM
redGSRguy
Suspension & Brakes
Oct 19, 2006 03:39 PM
DriveSlowHomie
Suspension & Brakes
May 15, 2005 05:24 PM
