**PROBLEM**
Old Mar 28, 2008 | 10:36 AM
UCNTCME's Avatar
Default **PROBLEM**
Heres the short version. I recently put a b18b1 motor into my ek coupe. Obd1 motor to obd2 car.. So its been running for like 2 weeks. And everytime I turn on the car it takes a little bit longer to start up. And once it turns on it revs between 2000 and 2500rpms. then slowly it goes down till it eventually get to 1000. So today a couple minutes ago I went to grab some food and when I tried to turn on my car it wouldnt start. So i kept trying it. Till it finally turned on. When I was driving backhome my rpm gauge started flipping out while I was in 3rd gear 4th the same and 5th aswell. I dont know what happened then it just suddenly stopped working. After when I pressed on the gas it did have the same potential it had from b4. so I drove it all the way home. When i turned off my car i tried to turn it back on an this time it wouldnt start back up. If anyone knows what the problem might be pls let me know. Maybe what things to check. Well ill be waiting Thanx!
Old Mar 28, 2008 | 10:51 AM
UCNTCME's Avatar
ANYONE!?
Old Mar 28, 2008 | 11:11 AM
UCNTCME's Avatar
TTT
Old Mar 28, 2008 | 11:15 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (UCNTCME)
Your extremely vague title doesn't help your case. Something like:
"OBD1 LS into OBD2 EK - Revs Funny, and Now won't start!!!" might be a much better attention grabber.
Having said that if the tach jumps around that sounds like a distributor problem. that could explain the difficulty starting too.
As far as the idle issues goes you need to give us more info such as:
Which ECU you running?
Is the check engine light on? What codes?
Help us help you
Old Mar 28, 2008 | 11:32 AM
UCNTCME's Avatar
Sorry.Im still rather new to the racingscene. Im using the p75 ecu.The check engine light is on but I dont know how to check for codes. As for the dizzy I put an obd2 dizzy on the obd1 motor think thats what caused the problem?
Old Mar 28, 2008 | 12:06 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Which P75 did you use? OBD1 with jumper harness? OBD2?
Old Mar 28, 2008 | 12:12 PM
UCNTCME's Avatar
I used the same one i got with the swap. obd1 p75 with and obd2a to obd1 piggyback.
Old Mar 28, 2008 | 12:39 PM
tazeat's Avatar
.. Well check your code, and report back...
Old Mar 28, 2008 | 12:58 PM
UCNTCME's Avatar
dont know how to check for codes. typed that in one of my posts
Old Mar 28, 2008 | 01:01 PM
honduh_head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCNTCME &raquo;</TD></TR><TR><TD CLASS="quote">dont know how to check for codes. typed that in one of my posts</TD></TR></TABLE>
search this site for code finding....there's a lot of info and how-to on it.
Old Mar 28, 2008 | 01:08 PM
ho bag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCNTCME &raquo;</TD></TR><TR><TD CLASS="quote">I used the same one i got with the swap. obd1 p75 with and obd2a to obd1 piggyback.</TD></TR></TABLE>
So if your using an OBD1 ecu dont you have to use and obd1 dizzy too?
Old Mar 28, 2008 | 01:11 PM
UCNTCME's Avatar
Im not sure. The is the 2nd swap ive done on my own the first was sohc and this is my first bseries.
UCNTCME
Mar 28, 2008 01:31 PM
Meatwad1355
Jul 1, 2007 08:12 AM
solofthesouth
Apr 9, 2006 06:52 PM
SPOOLIN
Jun 19, 2002 09:42 AM
