tps check/adjustment
Old Mar 28, 2008 | 09:18 AM
92egSnatch's Avatar
Default tps check/adjustment
i searched and found this but i stil need a little help
its a 92 vx d15z1
but i only see 3 holes to check voltage the green wire is comming up .5
but the other 2 dont show anything with the car off can some one help me out am i doing somthing wrong or is my tps just bad?
You need to connect a multimeter to the tps and move the sensor around until the correct ohm specs are achieved.
With the TB closed, sensor disconnected, ign off:
Pins 1 and 2 = 0.5-0.9ohms
Pins 2 and 3 = 3.6-5.4ohms
You also need to be sure you have correct voltage, sensor connected, ign 'on':
Pins 1 and 3
0.5volts with the TB closed
4.5volts with the TB fully open
Old Mar 28, 2008 | 09:52 AM
92egSnatch's Avatar
Default Re: tps check/adjustment (92egSnatch)
bump
anyone?
dangerous_d
Mar 23, 2016 08:30 AM
DeDonDeRosa
Mar 21, 2013 06:10 PM
valentine97
Jan 14, 2008 12:44 PM
Mr.Death
Feb 6, 2005 02:30 PM
hondaeg8
May 14, 2004 10:23 AM
