installing racing header
Yeah, you and going to need the proper sized donut gasket, and maybe the one that goes in between the cat and the catback. And more than likely your going to have to unbolt your sway bar to fit the header flange up to the cylinder head.
Ideally, you'd want to use gaskets where the pipes join up to each other but it can be done with out if your feeling ghetto. Just make sure you use something like exhaust cement to seal in any leaks.
RestoRoc89
Jan 28, 2018 09:48 AM
crazyboy
Oct 17, 2011 09:17 AM
The Notorious Frosty
Jan 26, 2009 06:14 PM
