lovefab manifold, civic alternator Qs'
when running this manifold can you still use Power steering? also do you have to relocate the alternator? does a civic alternator fit on the h22 bracket?
err....nevermind
here you go...d series alternator fits on THIS bracket, and mounts it where the AC was.
http://www.explicitspeedperfor....html
which manifold are you talking about, im pretty sure lovefab.. has several different ones..
if you going with the mini - me or or the mini me eq. you do not want to lower the altenator to where the AC compressor used to be..
and both mini me and mini me EQ are PS compatible..
this is regarding the H22 motor
im running h23 vtec. i understand not lowering the alternator. with the kit im ordering it is not possible to have the alternator in stock location. so i planned to move it or buy a different manifold.
i was leaning toward the mini-me eq. i want to know if i can leave the powersteering and alternator in stock location?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 »</TD></TR><TR><TD CLASS="quote">im running h23 vtec. i understand not lowering the alternator. with the kit im ordering it is not possible to have the alternator in stock location. so i planned to move it or buy a different manifold.
i was leaning toward the mini-me eq. i want to know if i can leave the powersteering and alternator in stock location?</TD></TR></TABLE>
yes.. it only requires that you remove AC
turtleman321
May 3, 2010 06:32 AM
spidermancivic
May 8, 2005 11:43 AM
