Spindle and Rotor Q's
Old Mar 28, 2008 | 02:16 AM
Horseofcourse's Avatar
Default Spindle and Rotor Q's
Which spindles are the same? Im pretty sure all EG's are. But are any ef's or Ek's the same as EG hatch spindles? Same with rotors. I just had a wheel bearing go out so i just wanted to see when poking around the junkyard if there was anything else i could look at. Also are EG SI's the same? And Del Sol's.
Old Mar 28, 2008 | 09:18 AM
Default Re: Spindle and Rotor Q's (Horseofcourse)
Old Mar 28, 2008 | 09:43 AM
ek4_b16a's Avatar
eg and ek's have the same spindles...you can reuse them...i know the egsi hatchs lx sedans brakes are a bit bigger than dx/cx...gl...if you could find some lx front spindles/lca's and sway bar, get that whole thing and swap them on your car if you don't have front sway bar....gl again!
Old Mar 28, 2008 | 09:50 AM
Default Re: Spindle and Rotor Q's (ek4_b16a)
Thanks for the help! much love
project civic
Jun 1, 2007 08:48 AM
Jon V
16
Jul 3, 2004 06:54 AM
speshuled619
Sep 13, 2002 04:42 AM
