clutch pedal to the floor and nothing
I've got a 96 del sol si with a b18c swap and not sure if they upgraded the clutch. Anyways...I got in the car tonight and stomped on the clutch...no spring action, no resistive force and straight to the ground and stayed there. Can't shift into gear. Too dark to see if there was a puddle under my car...happened on my way home so I'm not sure if it already leaked before I got home.
Any sugguestions to the problem I may be having?
Any help is appreciated.
Thanks.
Thanks.
cool thanks...I'll take a look..I think that might be the problem...it was intermittent for a little while...just pulled the pedal out and it worked for a little bit...thats how I got home. Will check fluid level when I get home. The mc and sc are right on the opposite side of the firewall where the clutch is right?...sorry for the noob questions, justing getting into the mech tech.
ej1-usdm
Dec 5, 2007 04:03 AM
dem0nk1d
Oct 26, 2006 12:01 PM
