T1 Cam Trigger Kit
Old Mar 27, 2008 | 09:41 PM
alpha's Avatar
Default T1 Cam Trigger Kit
I FINALLY got a chance to tune a car with T1's Cam Trigger Kit. We've a couple cars with them but none running yet. I can't say enough good things about it At the shop for fifteen hours today so I wont, haha
T1
T1 Cam Trigger Kit
Old Mar 27, 2008 | 09:59 PM
BoostedJeff's Avatar
Default Re: T1 Cam Trigger Kit (alpha)
This cam trigger has worked wonders for many! T1
Modified by BoostedJeff at 11:47 AM 4/1/2008
Old Mar 28, 2008 | 05:15 AM
tony1's Avatar
Default Re: T1 Cam Trigger Kit (BoostedJeff)
Old Mar 28, 2008 | 05:53 AM
Turbo-charged's Avatar
Default Re: T1 Cam Trigger Kit (tony1)
we wont tune an AEM car with out one, no exceptions.
Old Mar 28, 2008 | 07:08 AM
Blown90hatcH's Avatar
T1....never heard of her
Old Mar 28, 2008 | 07:15 AM
siblues's Avatar
Default Re: T1 Cam Trigger Kit (Blown90hatcH)
I have one and love it.It works wonders
Old Mar 28, 2008 | 07:43 AM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">T1....never heard of her </TD></TR></TABLE>
She called and said your intercooler is ready
Old Mar 28, 2008 | 08:22 AM
93LSivic's Avatar
I also run one. Without Tony many wouldn't be going 9's I'll get there hopefully
Old Mar 28, 2008 | 09:01 AM
carzntune's Avatar
Curiosity is killing me so I'll be the first to ask for elaboration on why is it so good? I guess I'll be specific to what I personally would gain by going this route. Here are my quick specifics if it helps answer the question:
Street driven 00 Si, fully built b18c running GT30R (.82 housing). It's at Evans Tuning right now being finished up. Stock ignition and Hondata S300.
Am I going to see better idle and a cleaner signal at higher rpm only? Maybe this is more geared towards race only, high power/revving engines. Learn me people!
Modified by carzntune at 3:51 PM 3/28/2008
Old Mar 28, 2008 | 09:05 AM
morgan@synapse motorsport's Avatar
Default Re: (93LSivic)
ive had a tony1 trigger kit, its decent. haha j/k its top knotch. def a neccessity on an AEM tuned car.
Old Mar 28, 2008 | 09:06 AM
Default Re: T1 Cam Trigger Kit (carzntune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carzntune &raquo;</TD></TR><TR><TD CLASS="quote">Curiosity is killing me so I'll be the first to ask for elaboration on why is it so good? I guess I'll be specific to what I personally would gain by going this route. Here are my quick specifics if it helps answer the question:
Street driven 00 Si, fully built b18c running GT30R (.82 housing). It's at Evans Tuning right now being finished up. So far making 505whp on stock ignition via Hondata S300.
Am I going to see better idle and a cleaner signal at higher rpm only? Maybe this is more geared towards race only, high power/revving engines. Learn me people! </TD></TR></TABLE>
you cant use it with the S300. but dont worry the hondata ecus read the oem dizzy a lot better than the AEM boxes do.
tony1's Avatar
It doesn't work with a Honda ECU, so you're off the hook. lol
The problem is with aftermarket ecu's (AEM, Motec, etc). They don't interpret the signals coming in from the distributor very well. Those signals control everything. All fuel and ignition events are triggered by those signals. If they are bad, everything is bad. The cam trigger has a digital signal that those ecu's understand much better and is much less affected by RF noise. Cleaner signal coming in means the car runs smoother and fuel and ignition events are more accurate.
Honda made their ecu specifically to work with their distributor, so it does not have those problems.
Old Mar 28, 2008 | 09:15 AM
carzntune's Avatar
I knew I'd have to up to AEM or the like. Just curious what that cost would equate to in gains whether it be gas mileage, smoother power, yadda yadda. I think I have my answer. Thanks!!
Old Mar 28, 2008 | 09:33 AM
st00pid's Avatar
I put one of those thingys on a civic and it went 9s. True story. That tony guy is a pretty smart cookie.
Old Mar 28, 2008 | 10:59 AM
88 yellow crx's Avatar
Default Re: T1 Cam Trigger Kit (st00pid)
Can T1 trigger be used with DFI?
Old Mar 28, 2008 | 11:13 AM
tony1's Avatar
Default Re: T1 Cam Trigger Kit (88 yellow crx)
Gen 6, no. Gen 7, possibly. You'd have to get with Accel and ask them. It needs to be able to see 6 "crank" pulses per revolution and 1 "cam" pulse per cycle from a Hall sensor.
Old Mar 28, 2008 | 12:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
She called and said your intercooler is ready </TD></TR></TABLE>
Awesome. T1
00CivicSi5spd
Jun 14, 2019 11:36 PM
00CivicSi5spd
Apr 15, 2019 03:01 PM
B's
May 25, 2017 04:04 AM
rollydc69
Aug 24, 2006 01:18 PM
Kicker773
Apr 5, 2005 03:49 PM
