Skunk2 intake manifold. with throttle body
Old Mar 27, 2008 | 06:35 PM
ShinkospeedEM1's Avatar
Default Skunk2 intake manifold. with throttle body
im about to buy a skunk2 intake manifold with throttle body.. not only will it help with hp. but it also looks real clean and will clean up my engine bay a little bit. the throttle body is what im worried about. I get to pick the size of the bore. 68mm/70mm72mm or 74mm. is 74 too much? it might be overkill. and will it mess up my air to fuel ratio.. or should i go for it?
thanks again for your help
Old Mar 27, 2008 | 06:38 PM
yoffer's Avatar
Banned
Unless your boosted, i wouldnt go higher than a 68mm. Just consider that a d series is a 56mm stock.
Modified by yoffer at 7:51 PM 3/27/2008
Old Mar 27, 2008 | 06:48 PM
I have a b16 i think stock size is 68mm
Old Mar 27, 2008 | 06:50 PM
yoffer's Avatar
Banned
No, its 58mm
*Edited my last post*
Old Mar 27, 2008 | 06:55 PM
my bad dude i thought scince you said>>> Just consider that a d series is a 56mm stock. i thought you might have thought i had a d series.. i didnt know that a B sieries and a d series had the same stock mm
Old Mar 27, 2008 | 07:00 PM
yoffer's Avatar
Banned
Default Re: (ShinkospeedEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinkospeedEM1 &raquo;</TD></TR><TR><TD CLASS="quote">my bad dude i thought scince you said&gt;&gt;&gt; Just consider that a d series is a 56mm stock. i thought you might have thought i had a d series.. i didnt know that a B sieries and a d series had the same stock mm
They dont, d series is 56mm, b16 is 58mm.
Old Mar 27, 2008 | 07:09 PM
ight thanks man
Old Mar 27, 2008 | 07:12 PM
soo 72 would be safe...no boost all motor..or go with 74
Old Mar 27, 2008 | 07:17 PM
yoffer's Avatar
Banned
Why? Anything over 68mm on a n/a is overkill.
Old Mar 27, 2008 | 07:19 PM
Default Re: (yoffer)
that works thats all i needed to know.. thanks again..
Old Mar 27, 2008 | 07:23 PM
yoffer's Avatar
Banned
You can get a 72mm or whatever, do what you please, but your going to kill your top end. The only thing your gaining from a 70+ tb is volume, thats it. Your gaining volume, but losing velocity. Velocity is what gives you that high end hp. Like i said before, unless your boosted, dont go over 68mm.
Modified by yoffer at 8:31 PM 3/27/2008
Old Mar 27, 2008 | 07:29 PM
noo i didnt want to get anything that would be overkill.. i wasent pushing for the 72mm.. im glad you jumped in and gave me the info.. im going to go with the 68mm.. not that it matters much but.. the password jdm cf power chamber intake/skunk2 manifold and 68mm throttle bodie should be an alright set up..
Old Mar 27, 2008 | 07:35 PM
yoffer's Avatar
Banned
Sounds good, how does your exhaust setup look like?
Your not going to benefit much from the intake setup if your motor cant expell the exhaust gasses efficiently.
Old Mar 27, 2008 | 07:39 PM
spoon 4-2-1 headers and a full greddy evo exhaust.. wll i keep the rest of the greddy and switch to a spoon axle back. not that it matters..
Old Mar 27, 2008 | 07:42 PM
yoffer's Avatar
Banned
Well, youll net some pretty decent gains from the intake bolt-ons.
You might want to look into bypassing the fitv and the iacv coolant lines to keep your air intake temps down.
Old Mar 27, 2008 | 07:49 PM
lol alredy did i love that trick.. im not sure but ive herd a 10hp gain from that....even if it doesnt gain that much its alot better than sucking hot air into the motor..
Old Mar 27, 2008 | 07:51 PM
yoffer's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinkospeedEM1 &raquo;</TD></TR><TR><TD CLASS="quote">lol alredy did i love that trick.. im not sure but ive herd a 10hp gain from that....even if it doesnt gain that much its alot better than sucking hot air into the motor..</TD></TR></TABLE>
Gas mileage and horse power FTW
Old Mar 27, 2008 | 07:59 PM
i also just ot my jun cams and toda cam gears. but i might save them until i change my stock vaulve train
Old Mar 27, 2008 | 08:16 PM
v!taminb16's Avatar
i have a skunk2 intake manifold and i have a blox 70mm tb that doesnt affect my top end i just need to get retuned i have a b16a2
elementwong
Sep 24, 2016 04:59 PM
skunk2.com
Performance
Aug 27, 2013 07:17 AM
jdmstockeg6
Sep 10, 2007 08:05 AM
phantasticphan
Feb 6, 2007 12:35 PM
YoungMoneySi
Jan 26, 2006 11:49 AM
