h2b w/ auto trans good or bad?
Old Mar 27, 2008 | 05:49 PM
scott_kusch's Avatar
Default h2b w/ auto trans good or bad?
h2b with an auto trans would it be a good idea for more consistant times? anyone please i need inputs positive or negative i havent decised yet
Old Mar 27, 2008 | 10:26 PM
StylishDOHC's Avatar
Default Re: h2b w/ auto trans good or bad? (scott_kusch)
Automatics use a different mount for the tranny, so the h2b kit won't work.
Old Mar 28, 2008 | 06:34 AM
~sp33~'s Avatar
EFB055
Theoretically an automatic would give more consistent drag times.
There was a thread on this in the hybrid section a couple of day's back. It ended with the same answer though "auto + h2b = won't work"
Old Mar 29, 2008 | 03:48 AM
StorminMatt's Avatar
Default Re: (~sp33~)
The B-series automatic transmission is also physically VERY large compared to the manual. I don't know that it would even fit.
Old Mar 29, 2008 | 04:04 AM
gibsanez's Avatar
Default Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">The B-series automatic transmission is also physically VERY large compared to the manual. I don't know that it would even fit.</TD></TR></TABLE>
I couldn't really see it being worth it either. I'd rather just practice my consistency with a short geared 5 speed than wait for my "consistent" long geared 4 speed auto to blow up
Old Mar 29, 2008 | 04:13 AM
helpmycivic's Avatar
just go 5 speed bro. practice makes perfect. and like stated before the auto trans is much larger and the mounts are diff and would have to be fabbed up. but if you got the $$ and that what you want then go for it. just my $.02
Old Mar 29, 2008 | 05:11 AM
Default Re: h2b w/ auto trans good or bad? (helpmycivic)
Here's something else to consider. Automatic transmissions have greater HP losses. So a given motor with an automatic is going to have lower WHP for a given crankshaft HP. In other words, although your times might be more cosistent, they will just be more consistently slow.
Old Mar 31, 2008 | 09:40 AM
skunked's Avatar
Default Re: h2b w/ auto trans good or bad? (StylishDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StylishDOHC &raquo;</TD></TR><TR><TD CLASS="quote">Automatics use a different mount for the tranny, so the h2b kit won't work.</TD></TR></TABLE>
I don't think that would be an issue. The starter would be my first concern.
blu_ej
Apr 16, 2008 01:25 PM
95civiccpdx
10
Aug 13, 2007 06:16 AM
nix94delsol
May 2, 2007 09:07 AM
FrostyDC4
Acura NSX
19
Dec 5, 2005 08:04 PM
