Advanced Ign. timing? few questions
Old Jul 9, 2002 | 03:32 PM
ITRaholic's Avatar
Default Advanced Ign. timing? few questions
What is the stock ° on the ignition?
how much should i change it? 18°?
what is the nr 1 piston if you stand in the front of the car?
Old Jul 9, 2002 | 03:34 PM
reefer_bob's Avatar
Default Re: Advanced Ign. timing? few questions (RedintegraR)
16 +/-2
Yes.
Right Side.
[Modified by reefer_bob, 4:53 PM 7/9/2002]
Old Jul 9, 2002 | 03:35 PM
EagleR's Avatar
16 deg +/- 2 deg. Dyno test it....some like it all the way up to 18 some will start dropping off.....
My friends loves 18 deg...and makes good power there....
Mine doesn't like anything more that 16.5 or so.....
It's a car by car basis, so the only way to see what you need is on a dyno....
Old Jul 9, 2002 | 03:36 PM
ITRaholic's Avatar
Default Re: Advanced Ign. timing? few questions (EagleR)
thanks for the answear so quick! H-T 0wns
Old Jul 9, 2002 | 03:42 PM
poison's Avatar
Default Re: Advanced Ign. timing? few questions (reefer_bob)
16 +/-2
Yes.
Left Side.
16 +/- is correct
Yes, that is fine.
And standing in front of the car the #1 Piston is on the right side -- the one furthest from the distributor.
Old Jul 9, 2002 | 03:53 PM
reefer_bob's Avatar
Default Re: Advanced Ign. timing? few questions (poison)
Oh $hit... my bag... You are correct Poison... 1 is on the right... I'm tired, and it's time to go home, it's not my fault...
Old Jul 9, 2002 | 05:28 PM
EagleR's Avatar
I didn't even see that question to answer or know what u were talkin about....looks like I'm gettin Net weary here too....
Old Jul 9, 2002 | 05:48 PM
poison's Avatar
lol, it's ok i even screwed up here too about oil and put changing ur oil every 30,000 instead of putting 3,000 miles to me
[Modified by poison, 7:48 PM 7/9/2002]
Old Jul 10, 2002 | 04:21 AM
ITRaholic's Avatar
thanks again guys
Old Jul 10, 2002 | 08:00 AM
ITRaholic's Avatar
something more i need to know?
Old Jul 10, 2002 | 08:01 AM
DutchITR1689's Avatar
Maybe reset the ECU? Don't know if it helps, but it won't hurt!!!
Old Jul 10, 2002 | 08:05 AM
JPP's Avatar
JPP
You need to "jump" the service connector (is that how it is called) located near the ECU on the passenger side while you do the adjustment. Otherwise the ECU will compensate for whatever modification you will do. Go to c-speedracing.com for a good step by step description.
Old Jul 10, 2002 | 08:06 AM
SoCal ITR's Avatar
Default Re: Advanced Ign. timing? few questions (DutchITR1689)
Well, you need to short out part of the system, then start the car, change the timing, pull out the paper clip you used to short out part of the system and then turn the car off. Then it will stay at 18, otherwise it will drop back to 16 if you turn the car off and the pull the clip.
Adam_b16a
Sep 29, 2009 05:59 PM
PrecisionH23a
Jan 21, 2005 01:55 PM
emotionisdead
Dec 23, 2004 03:52 PM
Eric R
Jun 12, 2003 05:11 AM
TypeR 1159
Apr 8, 2002 03:24 PM
