Base Ignition Timing???
Old Sep 28, 2009 | 11:57 AM
Adam_b16a's Avatar
Default Base Ignition Timing???
What do you guys have your base ignition timing set on your distributor??? Should i leave it at stock 16btc or retard it?
Old Sep 28, 2009 | 12:26 PM
b20beast83's Avatar
Default Re: Base Ignition Timing???
leave it stock, 16* and get it tuned
Old Sep 28, 2009 | 12:58 PM
Adam_b16a's Avatar
It is street tuned. Right now i have it at 14* but i wasnt sure if i should advance it back to 16* or leave it how it is??
Old Sep 28, 2009 | 12:59 PM
96 GSR-T's Avatar
leave it where it was when it was tuned, whoever tuned it should of confirmed 16deg base before he tuned it
Old Sep 29, 2009 | 06:29 AM
93supercoupe's Avatar
you could put it back to 16 and gain some power, but read your plugs and check your wide band regularly
Old Sep 29, 2009 | 08:01 AM
raene's Avatar
I've always wanted to know how much the distributor angle affects injector phasing and how much that relates to power.
Just something to think about. I wish some of the more knowledgeable-with-OEM-parts guys would chime in here (blundar, J. Davis).
Old Sep 29, 2009 | 05:54 PM
Adam_b16a's Avatar
Well, it was street tuned and my tuner used a handheld wideband. I dont have one. I had the ignition on 14* at the time and i was just curious if i could advance back to stock 16* in hopes of a little better gasmileage and better throttle response. I have been checking my plugs reguarly and they seem ok, not bleached white and not dark either.
Old Sep 29, 2009 | 05:59 PM
slow96lude's Avatar
I would just leave it where it was tuned at. Just curious because Im kinda close to you, Who does your tuning or the business? I tune crome but am wanting someone to do something with an aem or hondata
FlewByU352
Nov 13, 2010 07:27 PM
ohsnapzafingcu
Engine Management and Tuning
14
Sep 28, 2009 07:54 PM
emotionisdead
Dec 23, 2004 03:52 PM
DutchITR1689
Oct 12, 2004 01:17 PM
Keane Rated R
May 13, 2002 09:37 PM
