cleaning pistons
Old Jul 9, 2002 | 02:57 PM
erniecars's Avatar
Default cleaning pistons
I searched for this but couldnt find anything. How can i clean the faces of my pistons with the head off? I tried gasoline but it didnt do much and carb cleaner does even less.
Old Jul 11, 2002 | 03:29 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: cleaning pistons (erniecars)
very soft brass wire brush wheel in a hand held drill.
Old Jul 11, 2002 | 01:57 PM
erniecars's Avatar
Default Re: cleaning pistons (Mista Bone)
I soaked them in wd40 and the grime washed off. thanks.
Old Sep 26, 2003 | 08:55 PM
Hoosier Daddy's Avatar
Bringing this thread back. Is it safe to clean pistons by soaking them in something, such as WD40 like ernie did? Should I stay away from anything? Thanks!
Old Sep 27, 2003 | 06:35 AM
LudeyKrus's Avatar
yeah, WD40 won't hurt anything.
Old Oct 31, 2003 | 03:57 PM
Bizarre's Avatar
Default Re: (LudeyKrus)
You think simple green with an sos pad(The finner type)would also work?
Old Oct 31, 2003 | 05:03 PM
LudeyKrus's Avatar
I would say it would work, but I would pull the pistons out before doing anything other than spraying on a solvent and wiping it off w/ a rag.
I would be afraid of some of the scratchings frmo the wire brush or abrasive surface getting down into the ring lands...at least w/ the pistons out, you could wash everything off afterwards.
I've heard of some VW guys revvin the motor up and slowly pouring in a cup of water; the water turns to steam when combusted turns to steam and cleans the pistons....not to be tried at home, though....
Old Nov 3, 2003 | 01:23 PM
Bizarre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I would say it would work, but I would pull the pistons out before doing anything other than spraying on a solvent and wiping it off w/ a rag.
I've heard of some VW guys revvin the motor up and slowly pouring in a cup of water; the water turns to steam when combusted turns to steam and cleans the pistons....not to be tried at home, though....</TD></TR></TABLE>
Oh yeah, I had the pistons out. Thanks for the info.
rotascircuit
10
Jan 8, 2010 10:42 AM
SurferDude905
May 26, 2009 05:08 PM
sk8board{Pete}
Oct 19, 2008 12:07 PM
TheLastSpartan
Aug 6, 2006 12:16 PM
sshaikh01
May 20, 2003 05:45 PM
