I just installed a system in my eg
Old Mar 27, 2008 | 08:01 AM
CiViCBruh's Avatar
Default I just installed a system in my eg
hey guys i just intalled a system in my car its a 1000 watt amp and what sometime happens is that when i am goin to stop i push the cluth in then the brake and its like my car dies and comes back on really fast. Also it ideals weird like it going to die or something
Old Mar 27, 2008 | 08:16 AM
bigsyke's Avatar
Default Re: I just installed a system in my eg (CiViCBruh)
Fix your brake booster
Old Mar 27, 2008 | 08:27 AM
weemanch's Avatar
Default Re: I just installed a system in my eg (bigsyke)
i'm also guessing could be when your system hits when it dies and its time for a bigger alternator or a smaller system
Old Mar 27, 2008 | 08:51 AM
96 EX's Avatar
Default Re: I just installed a system in my eg (weemanch)
To put a system in a compact car is kinda overkill so your either going to need to downgrade your amp or pick up a bigger alternator like the other man said. But as for your brake/clutch problem I have no idea. Hope you get it figured out
Old Mar 27, 2008 | 08:57 AM
blk92_d16's Avatar
The car is "dying" because the power draw from the alternator is too great with the new system. And no, a cap won't fix it. Time to look into a HO alternator.
BTW, someone post up the factory amperage of the alternator plz!
Old Mar 27, 2008 | 09:01 AM
bigsyke's Avatar
its dying from vacuum, I doubt the alternator would cause his car to die if he put the brakes and clutch in.
your brake booster is bleeding air in from somewhere
Old Mar 27, 2008 | 09:16 AM
Jakester9500's Avatar
Default Re: (bigsyke)
just because you were under the hood, and now having these problems, you should recheck your vacuum lines to make sure you didn't accidently bump one and knock it loose or something.
1000w in a civic is overkill
Old Mar 27, 2008 | 09:34 AM
bigsyke's Avatar
the ELD is probably opening up the IACV quite a bit, letting less vac into the PCV valve, resulting in a clogged PCV which may contribute to the stalling when the brake booster is applied.
Old Apr 16, 2009 | 08:51 PM
Otherkid's Avatar
OR I had a problem like this before. Im not saying dont check the vacuum lines because thats very possible. But if his system is wearing out his alt and he doesnt have a cap on it (so it is wearing that alt out) when he hits the brakes when the car is stopped (not necessarily when he pushes the clutch) and the brake lights come on with all his stereo equipment and **** on causing the car to die. But the battery is good so it cranks back up until everything loads back up system starts hitting. Then dies when he hits the brakes. Alot more reasonable answer than replacing the brake booster.
Old Apr 16, 2009 | 08:54 PM
civic_driver's Avatar
Yeah, Otherkid might be right on this one.
Old Apr 16, 2009 | 08:56 PM
TravisCadello's Avatar
Yes, A capacitor will greatly help. Don't lie to him.
Old Apr 16, 2009 | 08:58 PM
R666_EK's Avatar
This thread is fukin retarded and old. The amp is NOT too much. I have a 2000 watt amp in my coupe. Only get occasional dimming in the headlights. If it was due to the amp drawing too much current then YES a cap would help. But 1000w isn't going to be the issue. If the OP is still having a problem then I would check the brake booster as well. If the charging system is in good working order then the amp install is most likely just a coincidence or something he did during the install.
Old Apr 16, 2009 | 09:19 PM
98civdx's Avatar
Master Detailer
wierd i have a 1000 watt amp and a 400 watt amp and no problems at all.
blk92_d16 YES a cap will help!
take it in and have the alt checked for free... when your amp is turned on to where you normally listen to it, and see if thats the issue;. possibly a new better battery
gel cell, or something with a lil more power then the stocker
but i highly doubt the system is casuing that,
Old Apr 16, 2009 | 09:22 PM
sp00ledbseries's Avatar
Ibftl
Old Apr 17, 2009 | 09:08 AM
yamahapunk154's Avatar
I dont think its a problem with the system. I have a stock alternator in my 96 hatch running a 2000 watt RMS class d soundstream amp with no problems like that. Yeah it does dim the lights when i turn it up real loud.
Turn your system down & see if it still does it, your obviously drawing too much power somewhere.
A cap will help this a bit but a bigger alternator would def. be the way to go as well. Take a volt meter to your power wire on your amp & see how much power its drawing.
B16A CRX
Audio / Security / Video
Aug 22, 2007 01:40 PM
Lil_Wyte
Feb 10, 2007 04:08 PM
VisPreludeVtec
Jul 11, 2006 07:14 AM
hawado
Jul 5, 2005 07:35 PM
RallyRedGT-V6
Mar 30, 2004 02:09 PM
