bad steering rack??
Old Mar 27, 2008 | 07:45 AM
redboy183's Avatar
Default bad steering rack??
hey guys, i recently replaced my axles and wheels bearings but for some reason (after 30mph) my steering shakes incredibly to a point where it is not safe to drive what so ever....my b16 swap went in and my car used to be an automatic hatch (meaning it was power steering).....now im just curious if i dont have fluid going to the rack will it cause to break or wear out sooner? i replaced just about everything suspension wise too and the rack is my only option left it seems...what do you guys think??
Old Mar 27, 2008 | 09:12 AM
90efhatch's Avatar
Default Re: bad steering rack?? (redboy183)
I would get a manual steering rack and put in there. I am sure that the power steering fluid is needed on a power rack to keep it lubricated.
Old Mar 27, 2008 | 09:41 AM
dem0nk1d's Avatar
i picked up a manual steering rack for my lx a few weeks back. greased it all up and swapped out the power to manual. also if your going to do this swap. you'll need to save the power steering rubber bushing that's goes around the passangerside of the rack, that bolts up on the passanger side. you'll have to double the rubber peace up. with the manual and power-rack. you'll notice the manual is much thinner in size.
Old Mar 28, 2008 | 06:34 AM
redboy183's Avatar
Default Re: (dem0nk1d)
kk thanks for the help guys
Old Mar 28, 2008 | 06:44 AM
~sp33~'s Avatar
EFB055
Have you checked your wheels are correctly aligned and balanced? That would create a shake, and would be cheaper to replace then a steering rack.
Just thought i'd put that out there.
Old Mar 28, 2008 | 06:47 AM
dem0nk1d's Avatar
warped rotors too can affect this.
or busted axle
Old Mar 28, 2008 | 07:33 AM
slywfbpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">warped rotors too can affect this.
or busted axle
</TD></TR></TABLE>Yep, my problem was twofold. My left axle was bad, and I had warped rotors. Problem virtually disappeared after I fixed those two problems.
Old Mar 28, 2008 | 09:01 PM
redboy183's Avatar
Default Re: (slywfbpsi)
the brakes are new and i just replaced my axels thinking they were the problem but it def didnt fix anything
Old Mar 28, 2008 | 09:11 PM
7panget's Avatar
Default Re: (redboy183)
it shakes when u brake? mine shakes when i brake at 40-50 mph.. they said its the rotors but i change my rotors still the same........update if u resolve it
Old Mar 29, 2008 | 08:28 PM
redboy183's Avatar
Default Re: (7panget)
no, it just shakes all around lol braking, accerelating, turns, and so forth.......as a matter of fact today i was just turning the wheel in the garage when it was quiet and i heard a little whistling noise comming from the tubes of where fluid is supposed to be in the rack so in a way im hoping the rack is just done for bc my manual one is comming sometime next week
Old Apr 4, 2008 | 08:36 PM
redboy183's Avatar
UPDATE: so i just replaced my rack with a new manual one and although my steering itself feels way more sturdier than it did the crazy retarded shanking noise still occurs after 30 mph....like i said i checked everything else balljoints every bushing known to man only thing i didnt replace yet is the axels which i bought today from advance and will be throwing them in and go from there
gotenz90640
Mar 19, 2016 03:57 PM
DohcVtec77
Mar 19, 2016 03:34 PM
mikej94civex
14
Feb 12, 2010 06:31 AM
redboy183
Dec 18, 2007 08:11 PM
a11mtrhatch
Dec 24, 2004 07:25 AM
