piston to valve clearance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Point3 »</TD></TR><TR><TD CLASS="quote">hey guys i just clayed my motor and found out that i have .050 of clearance, is that safe enough to run the engine.
Yes, if you're confident that nothing gets closer than that you should be fine. Many builders consider .040" to be the closest clearance tolerance.
Just keep in mind that if something happens to the timing you will have potentially catastrophic consequences.
</TD></TR></TABLE>Yes, if you're confident that nothing gets closer than that you should be fine. Many builders consider .040" to be the closest clearance tolerance.
ok well i clayed the motor with the cam gears at 0, 0 is there any way to get a little bit more clearance by adjusting the cam gears?????
thanks in advance.
thanks in advance.
Sure you can. Just advance the exhaust cam and retard the intake cam. It might screw up your power curves no end but getting more clearance is easy.
Isn't having a potential for catastrophic failure because of fubard timing pretty much a standard with Honda engines? Why go out of the way to acquire more clearance than necessary?
Ausmith
48
Feb 26, 2007 12:31 PM
Syndacate
Jul 31, 2006 09:34 AM
carboy_honda
27
Mar 9, 2006 04:50 PM
mingbling96
Jun 11, 2005 02:21 AM
