Any brake/caliper upgrade for 4cyl 6th gen?
I'm thinking about beefing up my brake system this summer..
I usually get brembo blanks with performance pads. It does the job, but not 'good' enough for me. The major issue i encountered last summer for me was brake fading due to overheated brake fluid on one particular day..
I was thinking of getting back to the usual setup, and perhaps adding S.S. braided lines to all 4 calipers, aswell as flushing completely my fluid. But then it occured to me..Why not upgrade the calipers!? (especially front)
Now.. I've heard about NSX/Legend calipers used on 5th gens, but what about the 6th gen? Precisely a 2001 4cyl Coupe..
2 Pistons would be perfect, but i guess a single, bigger piston would do the job too.. Anyone did the conversion, or is aware about it? Parts i would need to make it fit? Would i need to proceed with a 5lug conversion too?
I also stumbled across the info that i would need to change the proportioning valve since the braking force wouldnt be the same anymore..
Please help me out
Thanks!!
Please help me out
Thanks!!
well im pretty sure you can i mean 5th gens use 6th gen parts look into the 5th gen upgrade just source out the same parts and im pretty sure it will just bolt together
I upgraded my 02 accord with fr tl calipers and discs.much bigger than stock.I also did the 5 lug conversion.changed the hubs only.the spindles are the same as 99-03 tl's.i used the tl calipers and brackets.it all bolted up,it looks great and most impotantly works great.
you could also put TLS/CLS brakes on the car but you gonna need 17" or larger rims. should be able to swap the spindle with everything attached and then use legend 2 piston calipers.
There's the "cobble things together" time honored method as discribed elsewhere, and there is this:
http://www.horsepowerfreaks.com/perf...Big_Brake_Kits
Big Brake kits.
There's also this:
https://honda-tech.com/forums/honda-accord-1990-2002-2/1990-2002-accord-faq-1664547/
the Honda-tech FAQ section. Look up your project under Brakes
P
Big Brake kits.
There's also this:
P
As said before, 92-96 Prelude VTEC rotors, and your choice of Legend GS Calipers (2-piston), 6th gen Accord V6 calipers, or 92-96 Prelude VTEC calipers. You can find most of these for cheap on PartsAmerica.com, but be sure to purchase a set that INCLUDES the caliper brackets. You'll need those.
Dont know how hard they would be to get in the States.... I have a 6th Gen that comes factory 5 lug and has twin piston calipers (similar to the newer NSX) & 11.8" Rotors.
Not too sure if this conversion has been done yet, but I would emagine it would be an improvement over stock.
Another option (which I'm considering) is the brakes from the latest 2008 Accord's but would mean a compulsary upgrade in rim size to fit.
Feel free to email me directly at noelkeenen@gmail.com due to me not being able to find this thread in the future.
