Pro-Series Traction Bars & Drive Shaft Shop (DSS) Axles & -*Great Prices*-Get'em here!
DSS Axles -time to beef up!
<U>Reply to the thread with your application and requested level, we will PM you will a price.</U>
DriveShaftShop (DSS) has been the leader in axle and drive shaft for sport compact for years. They are intune with the market’s needs, and as learn about how to get more power out of our cars each year, putting down larger HP numbers than ever before, DSS is right behind you with a new and upgrade Axle kit to make sure you can continue to put that power to the ground.
DSS Drive Shafts - Upgrade your axles
B or D Series -into EF/EG/EK 88-00 Civic & DC 94-01 Integra
H or F series -into EF/EG/EK 88-00 Civic & DC 94-01 Integra
K Series -into EF/EG/EK 88-00 Civic & DC 94-01 Integra
The start with bring level 0 axles to the market. Though these are not racing axles, you should find them superior to others so called “swap axles”
Using a chrome moly center bar, billet inner c.v. with the oversized tripod, New heat treat on our 1117 billet outer c.v. The outer c.v. is made with a single arc design, this is a wear advantage over the factory Honda dual arc design that tends to wear out prematurely. this is a superior axle for any stock replacement or swap.Axles come with removable ABS ring's (92-01). Price listed is for both left and right axles. These axles are designed as an alternative to cheap re-builts and inexpensive units for swaps (not for drag racing).
Upgrade -Moving up to level 2.9:
The unbelievable level 2.9 axles are now available; these axles are for the extreme street/track machine. Designed to handle 475HP forced induction or all motor cars (yes that's right) at the wheels. These axles are the result of our extreme track testing. The inner and center is borrowed from our track tested level 3 system using a new proprietary material, solid torsional center bars, chrome moly spline plug and high grade inner housings with oversized tripod. What makes this stand apart from the rest is the new outer C.V. made from high grade chrome moly that has one of the wildest heat treats known to man. During destructive testing it broke a 300m bar!!! It's designed to fit the standard 26 spline outer hub of the Honda/Acura platforms. These axles also come with removable ABS rings. Are you ready for the next major level? Price is for both left and right axles
Upgrade –level 3.9
Level 3.9 Axle/Hub system 600HP for the Honda civic with a swap from a 1990-1993 Integra B series motor and cable type trans/clutch (1 year warranty) This axle system is made and designed for the real fast street car or drag car with up to 600HP. This was our older level 5 (2004 and older) system and we have brought it out of retirement due to the fact a 600hp street car is now a normal thing. This has been one of the best know systems for a Honda platform to date and is still a staple in most tuner shops around the world. Again this kit is for a civic with a B series motor/trans swap with a cable clutch from a 1990-1993 Acura Integra (For the Japan Spec SIR Y1 see other listing) the kit comes with both axles made from 300M with billet inner housings, the outer c.v. is 20% larger and is made from a Proprietary material that is ultra strong. The kit comes with a custom hub that is an exact replica of the factory one it just has the larger spline inside. The kit can be ordered here with either long ARP racing studs or a set of standard length ones. This set is considered Extreme for an extreme car.
this system does not come with ABS. the rings can be installed for an extra 100.00 (not discountable)
Ultimate upgrade level 5.9
This is the new level 5.9 axle/hub set similar to our level 5 system but with a major upgrade, the inner c.v. We now have created a Pro-Level Race worthy system that works with the standard spline size on the differential end, you can now use our System with Quaife and other aftermarket limited slip diff's and spools. What we have done is make a new ball & cage inner c.v. made from high quality chromoly. This inner C.V. now has 6 contact points and is stronger than a Porsche 930 (108mm) c.v. (same .v. used by many high dollar systems)This along with the 33 spline outer and 36 spline bars makes it the strongest set of axles to date. The Kit comes with both axles a set of custom hubs that will only fit the larger bearing sizes (click back button and see link for more hub info) the kits also comes with long ARP studs. The system is designed for 1000WHP and tire size will not effect its strength, don't forget to check out our intermediate bars and spools also listed on the site. If you need this system custom made please don't hesitate to call/e-mail, we have an entire wall of axles bars in many different sizes, we would be able to make a custom set in a very short time. DSS is dedicated to bringing you the best drive train products at a an affordable price, when your serious look our way
Avid Racing Pro- Series Traction Bars
EF 88-91 Civic/CRX
EG 92-95 Civic
EK 96-00 Civic
DA 90-93 Integra
DC 94-01 Integra
Front Mount released:
Traction Bar Front Torque Mount
Front Torque mount for mounting to your Avid or other applications may work as well. Adjustable, so it will work on your B and D Series for DA, DC, EF, EG, EK
Applications:
1998-2000 Honda Civic / CRX / Del Sol (all models with Avid traction bar)
1990-2001 Acura Integra (all models with Avid traction bar)
Visit our other H-T forum postings:
https://honda-tech.com/zero...age=1
Upgrade –level 3.9
EF 88-91 Civic/CRX
EG 92-95 Civic
EK 96-00 Civic
DA 90-93 Integra
DC 94-01 Integra
Applications:
Don't forget.......Just give us a BUMP for your BEST PRICE!!!
We'll shoot you a PM with your pricing.
<U>Bump this</U>
<U>Bump this</U>
B or D Series -into EF/EG/EK 88-00 Civic & DC 94-01 Integra Level 2.9 Also Avid Sway bar for DC2 Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com »</TD></TR><TR><TD CLASS="quote">Don't forget.......Just give us a BUMP for your BEST PRICE!!!
<U>Bump this</U>
<U>Bump this</U>
<U>Bump this</U>
what is the best price on traction bars for non si ek.
<U>Bump this</U>
<U>Bump this</U>
<U>Bump this</U>
jdmcars.com
38
Nov 30, 2008 01:43 PM
