This is really weird
Old Mar 26, 2008 | 06:58 PM
riftonthemind057's Avatar
Default This is really weird???????????
Okay I have a d15b2. I'm having electrical issues. The car when it starts reads 5 volts at the tps, the iat sensor and eagr sensor like it should after about a couple seconds the voltage raises on all of those sensors in turn shutting off the car. Now I have checked all of my grounds throughout the car tried replacing the ecu with a known good one and still does the same thing. I'm in the process of checking my dizzy right now. I'm not really seeing anything wrong is there anywhere I can get a break down of my distributor I'm using an si distributor td-02u. I have done a dpfi to mpfi swap. I'm using a pm6 ecu. Everything as far as wiring is looks great. I heard from a mechanic that sometimes very rarely a distributor may act weird and distribute voltage like a generator. I'm totally stumped if anyone has any ideas this would be very awesome especially if I can get a break down of the td-02u distributor.
Modified by riftonthemind057 at 8:37 PM 3/26/2008
Old Mar 27, 2008 | 09:45 AM
90efhatch's Avatar
Default Re: This is really weird??????????? (riftonthemind057)
When you did the dpfi to mpfi conversion did you switch the two outer wires on the TPS?
Old Mar 27, 2008 | 01:08 PM
Default Re: This is really weird??????????? (90efhatch)
I had a harness made for me by a performance shop. How would I check if thats been done or not?
Yuta
Oct 14, 2018 06:03 PM
88backhatch
Aug 14, 2005 04:45 PM
JDMSloLude
Feb 25, 2004 02:26 PM
showngo92
Oct 25, 2001 01:03 AM
