double clutching
Old Jul 9, 2002 | 01:31 PM
typRpwr1161's Avatar
Default double clutching
will someone please describe to me what double clutching means, what it does, and how you do it? Describe this to me like you would someone who doesnt know alot about engines, because i dont.
Old Jul 9, 2002 | 01:34 PM
Hybrid ctr's Avatar
Default Re: double clutching (typRpwr1161)
The search is your friend
This thread will explain everything
https://honda-tech.com/zerothread?id=161578
Reid's Avatar
Global Moderator
Do a search, noob.
Reid - who only tells others to do searches after doing a search himself, and finding adequate results...
Old Jul 9, 2002 | 01:35 PM
BDiddy's Avatar
Default Re: double clutching (Hybrid ctr)
dont granny shift either...
Old Jul 9, 2002 | 01:39 PM
RTW DC2R's Avatar
stop watching Fast N Furious so much. Its just a movie, and cars that blow up like that Eclipse, cant outrun cops afterwards.
2nd, double clutching is when you downshift, but rev match at the same time. The point of it from what I understand is to keep the RPM up and also to keep the exhaust note the same to disguise your shift(so the competition doesnt know you downshifted). There are 2 different methods to do this..heel-toe, and plain old boring double clutching. I personally like the plain old boring method because I cant turn my feet enough to gas and brake at the same time.
3rd, try a search because Im sure there is something on this board related to this.
4th, Im bored.
werd.
Old Jul 9, 2002 | 01:47 PM
slowassR's Avatar
Default Re: double clutching (RTW DC2)
rev matching
Old Jul 9, 2002 | 02:03 PM
Spedeeman's Avatar
I agree that the search has enough info in it, but to correct you, it is not just downshifting with rev-matching. That is simply 'heel-toe'. Double clutching goes further, as it originated from cars without synchros, where rev-matching alone will not be enough to save from wear on the gear box. The process of double clutching outlined in the post above basically eliminates the use of synchros when done correctly, and thus puts less stress on the gearbox/synchros. It has nothing to do with exhaust note or making your downshift seem like it hasn't happened to others, it is to prevent wear on the tranny, and it is so that the car doesn't have a violent reaction under load as it would if you didn't rev match or double clutch.
Old Jul 9, 2002 | 02:20 PM
davidnyc's Avatar
1. Push clutch in.
2. Move shifter to neutral
3. Let clutch up
4. Hit gas to match revs
5. Push clutch in
6. Downshift
7. Let clutch up.
Should take about 2-3 seconds to do the above when good. Also, this is usually done when part of your right foot is on the brake (Heal - toe)
[Modified by davidnyc, 6:20 PM 7/9/2002]
[Modified by davidnyc, 6:22 PM 7/9/2002]
Old Jul 9, 2002 | 02:27 PM
ITR21's Avatar
Default Re: double clutching (davidnyc)
u dont need to double clutch just get 3 bottles of nos and you will be running 9's. Hell why dont you just get 4. Isnt that how it works.
double clutching
Old Jul 9, 2002 | 02:28 PM
01-1293's Avatar
Default Re: double clutching (ITR21)
don't blow the bolts on your intake manifold
Old Jul 9, 2002 | 02:29 PM
Spedeeman's Avatar
NOS for a downshift? Hmmmm Someone watched F&F a bit much, as thats the only place I've ever heard of someone feeling the need to double clutch on an upshift, especially drag racing...
Old Jul 9, 2002 | 02:35 PM
d8168055's Avatar
how stuff works dot com... http://www.howstuffworks.com/transmission2.htm
scroll to the bottom... read the 2nd to last bullet...
boostede46
May 13, 2008 05:49 PM
TypeRaven
13
Mar 26, 2003 07:40 AM
Chris
Oct 28, 2002 08:15 AM
austrian type-R
Apr 7, 2002 10:48 AM
