Need help asap!!Spindles on b16 crx
Ok, here is the deal. I had really bad wheel bearings on the 1990 b16 crx. So I went to the junk yard and picked up a real good set of 4dr spindles and knuckles. I swap those two over, but now my car won't move. I jacked up the car and try to spin the wheel, but its stiff as a rock. I am using bseries axles and it goes into the splines perfect, but once i tighten the axle nut, it wont spin. Please help me figure out the problem!!!!!
From: I told you to wait in the truck in Texas, United States
Take the axle out of the hub and use a hammer
and flat chisel to pop it out..
It is "pressed" into the back of the hub..
Ok, i took out the entire knuckle and stuck a flathead screwdriver there but nothting prys out. I stuck it on atleast 2 cm. I think the dust seal is off already. The piece I am tryin to pry off stamps " JAPAN NIN" or something. I believe that is the bearing right???
Ok, to my best understanding the dust ring/seal is NOT there. But the wheels still won't spin when everything is attached. Please help me out, I need my car running for work on friday. Is there more pieces I need to take off a 4door knuckle to make it fit??
some of the spindles are not interchangable due to several different brake calipers being avalible for 88-91 chassis. so u may need the calipers and pads to finish ur swap. i experienced this problem before its not the axles, also im pretty sure the disks themselves are all the same, but i would take one of ur current ones with u and make sure vs the ones on the 4 door.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal B18b 4dr »</TD></TR><TR><TD CLASS="quote">some of the spindles are not interchangable due to several different brake calipers being avalible for 88-91 chassis. so u may need the calipers and pads to finish ur swap. i experienced this problem before its not the axles, also im pretty sure the disks themselves are all the same, but i would take one of ur current ones with u and make sure vs the ones on the 4 door.</TD></TR></TABLE>
Well, i am using my stock crx rotors, pads, and calipers. My only complication is the axle touching the wheel bearing.
I was under the impression that the hubs are different between the 4dr's and the hatch/crx's, although I could be wrong because we haven't really dealt with that issue before. One of our customer's I know is still looking for a passenger side EX 4dr knuckle which from my understanding is different than the typical civic/crx knuckle assembly. Best bet would be trying to get another set that came off a crx. Anything thats not a STD or HF will fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90LSpimpin »</TD></TR><TR><TD CLASS="quote">I was under the impression that the hubs are different between the 4dr's and the hatch/crx's, although I could be wrong because we haven't really dealt with that issue before. One of our customer's I know is still looking for a passenger side EX 4dr knuckle which from my understanding is different than the typical civic/crx knuckle assembly. Best bet would be trying to get another set that came off a crx. Anything thats not a STD or HF will fit.</TD></TR></TABLE>
Damn, well with that in mind. Does any have have a set of crx knuckles? Willing to trade for one that is off a 4dr. I want local and asap!!!!!! Well, I dont think 4dr ex's are different, they just offer a larger braking potential.
So noone knows if these kunckles would work on my car??? How do ppl with 4dr ef's do their bseries swaps then?
I went to a honda parts website and the caliper land knuckles have the same part number on 90-91 vehicles except for 90-91 EX.
But 88-89 vehicles everything was different. knuckles rotors etc.
Modified by JUN. at 7:47 PM 3/27/2008
Modified by JUN. at 7:52 PM 3/27/2008
beatthisspeed69
Feb 8, 2006 02:40 AM
