misfiring on #3
Old Mar 26, 2008 | 02:15 PM
Duck_man's Avatar
Default misfiring on #3
So i have an 01 lude. I just put a skunk 2 60mm tb on it and now it misfires. So i changed the plugs, wires, cap, and rotor, thinking that will solve the problem and to my disappointment it did not . Anyone have any suggestions?
Old Mar 26, 2008 | 02:32 PM
Acidcrakker's Avatar
Default Re: misfiring on #3 (Duck_man)
Coil is just about the only thing left.
Weird that you put a new tb on and it misfires now.
Put the old one back on and see if it stops.
ALso make sure the injector is plugged in too, might have broken a wire while working on car
Old Mar 26, 2008 | 02:38 PM
Duck_man's Avatar
Ahh forgot about the coil. yea i put the old one back on and it still does it. it runs really rich now too. like i drove less that 20miles and dropped over 1/4 tank. could have messed up an injector wire but meh. ill go tinker with it and let you know. thanks man
Old Mar 26, 2008 | 05:13 PM
Duck_man's Avatar
still runs like crap
Old Mar 26, 2008 | 07:45 PM
Have you replaced the coil. Its very hard to test a coil.
Old Mar 27, 2008 | 07:56 AM
Arsenal's Avatar
Default Re: misfiring on #3 (Acidcrakker)
When the car is idling, pull a wire off of a cylinder, one at a time, and take note if the idle changes on each one.
If the idle drops, then that cylinder is fine, if it stays constant, then that cylinder has a problem.
The pull the plug, place it in the wire and rest the metal part of the plug on the valve cover. Turn the engine over and see if it sparks.
If it sparks, then the injector is bad, if it doesn't, then its an ignition problem.
RobbyD
Oct 17, 2018 06:10 AM
hondatuningboi96
Jun 19, 2007 10:36 PM
pwhited
Jan 31, 2005 02:42 PM
t25hatch
Oct 20, 2004 11:10 AM
vteckilla7
Aug 8, 2004 01:41 PM
