question about aftermarket fuel pump installation ( safety first??? )
I bought a Xenocron fuel pump for my Sedan and had a question about the wiring part of the installation.
Do you solder the connections and heat shrink them. or do you use butt connectors? I ask cause it came with no instructions and what i did was use the oem connectors that sit in the tank and connect to the oem pump and splice them into the Aftermaket wires supplied by xenocron. Is that safe? will the chemicals from the fuel eat away at the heat shrink? The last thing i need is to blow up and never finish my sedan.
Info in appreciated as well as experience users who have dealt with installing similar pumps like this or a walbro.
Thanks!
Thanks!
Splock
Jul 30, 2017 08:57 AM
