Hey YOU!
Old Mar 26, 2008 | 01:04 PM
driftam1's Avatar
Default Hey YOU!
wats the redline of a stock d15b with dual point fuel inj.? the reason im asking this is cause mine is still at 3500rpr mabe if im lucky 4000rpms ? i fixed my code 10 and nothings changed i have no more ecu codes would it have any thing to do with having an hf tranny?
Old Mar 26, 2008 | 01:06 PM
Ermil's Avatar
Default Re: Hey YOU! (driftam1)
Are you trying to go fast in it? Sounds like you are bouncing off the rev limiter. What gear are you trying to test this lil redline gimmick out on?
Old Mar 26, 2008 | 02:31 PM
driftam1's Avatar
Default Re: Hey YOU! (Ermil)
well first and second my car isnt fast enough to go to top of 3rd gear i cant hardly go past 75-80 mph.
Old Mar 26, 2008 | 02:47 PM
f-it3's Avatar
pull the hazard fuse for a couple seconds...that will reset the ecu to clear that code, then try it...sounds like your car is in limp mode.
Old Mar 26, 2008 | 02:58 PM
driftam1's Avatar
Default Re: Hey YOU! (f-it3)
i check my fuses and i cant find the hazard fuse which 1 is it and it is under the steering colum under the dash right ?
Old Mar 26, 2008 | 03:03 PM
mugencx's Avatar
just take off the negative cable on the batt for 15min and that should also reset all codes on the ecu.
Old Mar 26, 2008 | 03:40 PM
SIred91's Avatar
Rainman
Default Re: (mugencx)
Good grief at all you people with bad information.
If you pull the main fuse in the fuse box under the hood on the passenger side shock tower, you should wait about 10 minutes.
THe EASY way to do it is to pull the NEG battery cable and put it back on, that only takes just a few seconds to reset.
Old Mar 26, 2008 | 10:20 PM
2slow4stock's Avatar
Ditto with SIred
Old Mar 27, 2008 | 02:28 AM
~sp33~'s Avatar
EFB055
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftam1 &raquo;</TD></TR><TR><TD CLASS="quote">my car isnt fast enough to go to top of 3rd gear</TD></TR></TABLE>
lol!
phoenix_iii
Mar 14, 2009 05:01 PM
Chilloutdamn
Nov 22, 2008 12:05 PM
dj626
Sep 27, 2004 03:31 PM
