b16a tapping? and code 22 (repost)
Old Mar 26, 2008 | 11:22 AM
vbcrixmanz's Avatar
Default b16a tapping? and code 22 (repost)
ever since i bought the car the head has had a tapping or clattering noise at idle, low and high rpms. ive done the valve adjustment twice. once myself, and next by a way more reliable resource ha. the motor was cold, feeler gauges were correct, cylinder order and TDC were right. it won't go away and it's becoming annoying while im trying to save and build this motor. someone mentioned maybe something with a lost motion assembly? its constant and taps with the rpms.
22 - every other 3 or 4 times i go into vtec i will throw a check engine light, code 22. i know its for the vtec pressure valve, but unfortunately i have no idea about that. also the other day possibly because the car wasnt warm enough, vtec cut out at about 7000 or so as if there was a rev limiter there. then wants to cut off while idling after i run the car hard.
appreciate any help. thanks
jachrist
Sep 28, 2009 02:27 PM
vbcrixmanz
Dec 29, 2008 01:13 AM
3a_eg_hatch
Jun 28, 2008 01:24 PM
jasony0630
11
May 1, 2008 07:41 AM
vbcrixmanz
Mar 23, 2008 06:28 AM
