loss of throttle/no power
Old Mar 26, 2008 | 10:43 AM
boost2much4u's Avatar
Default loss of throttle/no power
hey to all,well let me start by building the vehicle
93 civic coupe dx.99 jdm ls swap,converted to obd-1=injectors,dizzy,engine harness,ecu of course, heres what happens ,ill be driving on freeway at 60,wide open throttle to 80,then maintain throttle position at 80,from anywhere to 5-30 seconds,and it will feel like i let completely off the gas,but my foot is on the pedal,give it gas and just sounds real deep,have to throw the clutch in for a sec,back to 5th and good for the rest of the time being,it only happens after full throttle on the highway,
replaced.......dizzy,injectors,fuel filter,engine harness,check all grounds,throttle body,spark plugs,spark plug wires,02 sensor,,, also surges in 1st,2nd somtimes
never feels like theres a loss of power,pulls all the way through 7 all gears,idles perfect, if theres any thing you guys and gals might think of let me know please,thanx
Old Mar 26, 2008 | 11:01 AM
crazyguy's Avatar
Default Re: loss of throttle/no power (boost2much4u)
hows the tension of your throttle cable? and also have u adjust tps with a multimeter before ?
Old Mar 26, 2008 | 12:16 PM
Default Re: loss of throttle/no power (crazyguy)
ive tried alot of differrnt tensions its medium now, asfar as the tps ive tried ITR thottle body un touched and stock ls untouched,never adjusted tps with multi meter though.
Old Mar 27, 2008 | 11:47 AM
ttt,please help any ideas? been tryin for months,its like chasing a fart in the wind.
Old Mar 28, 2008 | 10:39 AM
Default please help any ideas. (boost2much4u)
ttt before weekend, its getting worse,now on cold engine its bogging under heavey accelaration,untill engines warm cant find vacum leak,please help.
Old Mar 31, 2008 | 09:14 AM
Default Re: please help any ideas. (boost2much4u)
bump
nokturne
Mar 25, 2010 05:03 PM
JDMB20TDA
Sep 7, 2009 08:32 AM
SpeedoKing
Aug 6, 2007 03:09 PM
frostcivic
Oct 12, 2004 03:52 AM
sir2k
Apr 26, 2004 07:05 AM
