bossted s2000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Highspeedv-tec! »</TD></TR><TR><TD CLASS="quote">has any one boosted there s2000? if so id like to know a good kit to buy?</TD></TR></TABLE>
no you would be the first
i heard a D series turbo kit works well though
ebay FTW
ebay FTW
Turbonator
best bang for the buck
it's easy to install, and it gives you better fuel economy
Turbonator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Highspeedv-tec! »</TD></TR><TR><TD CLASS="quote">how would a d series turbo work if the engine sits in the engine bay a hole diffrent way?</TD></TR></TABLE>
because most D series turbo kits hat a 90 degree pivot lever allowing you to angle your turbo for maximum performance. this is why it works perfectly on the s2000, because the engine was rotated 90 degrees.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Highspeedv-tec! »</TD></TR><TR><TD CLASS="quote">what kind of gasket should i use & will the turbo mainfold bolt up?</TD></TR></TABLE>
just use some rtv
the manifold has to be flipped upside down to be mounted, using extended double thread bolts
just use some rtv
you will be fine with the stock gasket... but if you want to run the D-series manifold, it needs to be flipped upside down and mounted using double-thread bolts.
I would also recommend fabbing some sort of direct exhaust injection to maximize your performance as well.
the key to all this is converting the s2000 back to obd1. our ecu's are way too intelligent to accept boost. i think you need a p28 ecu.
i think if you search there is a special s2000 only converter harness that you can go from obd2 to obd1 with
however, your key won't work when you do this
so you will have to get a jdm custom made key....but you still will be able to lock your doors with the old one
yeah, there really arn't too many people who have ever boosted an S2k.
I have a buddy that has one though with a d-series turbo, which is pretty much the best one you can get.
he said that you need to get a vafc an set your v-tech to 3k rpm, because the turbo spools really quickly, and you will go so much faster if you lower the v-tech.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">i think he'd be the 3rd person ever to turbo an s2000
you would be my inspiration if you did it</TD></TR></TABLE>
I just talked to my buddy, and he has some extra parts laying around that he would sell you for cheap if your interested.
What's your budget look like?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">you would be my inspiration if you did it</TD></TR></TABLE>
lol...
What a helpful 7000th post i just had
lol...
i just talked to my boss Ted (who has been slowly accumulating D series turbo parts from ebay) and he said make sure to get quality parts like xs-power if you're going to do this
you don't want to sacrifice reliability of not just the motor, but the parts as well
tricked92accord
Nov 14, 2006 07:05 AM
