cam cover d16z6 d16y8 same?
Old Mar 26, 2008 | 07:52 AM
91integraLSVTEC's Avatar
Default cam cover d16z6 d16y8 same?
Hey guys I have a z6 blocked mated to a y8 head but i am using the d16z6 distributor, cam, adjustable cam gear and the d16z6 cam timing cover. I cant find the p2p cam cover so i used the d16z6 cam cover to find tdc for the cam. So far the car drives ok but seems to be lacking topend. Is there another way to check if the cam as at tdc without the cam cover? Are the d16z6 and d16y8 cam cover the same? Thanks in advance.
Old Mar 26, 2008 | 07:56 AM
IanB's Avatar
They are different, the cam timing on the Y8 is not the same as the Z6 IIRC.
Old Mar 26, 2008 | 08:00 AM
1992Si's Avatar
I believe the two lines on the gear line up with the top of the head. TDC will be up top on the gear.
check out http://www.turbod16.com or http://www.d-series.org
Old Mar 26, 2008 | 09:30 AM
Default Re: cam cover d16z6 d16y8 same? (91integraLSVTEC)
Well I looked up the honda parts catalog and both engine timing belt back covers are the same part number. I did time the engine correctly I probably just need a retune.
immikejones
Sep 7, 2005 08:21 PM
mikehawkBUiLT
Sep 30, 2004 08:20 AM
CivicSoul
May 25, 2003 02:09 PM
d357r0y
Apr 10, 2003 05:30 PM
d357r0y
May 6, 2002 07:04 AM
