UKDM Teg Type R 5 Lug ?
I am looking into getting the brakes off a 1998 UKDM integra type r
My question is
Does the UKDM use a 5 lug set up ?
also what size of shafts ? 32mm ? 36mm ?
I am getting the eingine out of this car also so will be using the teg drive shafts
So what do i need ?
Master clyinder
prop valve
front - knuckles,caliapers and hubs
vack - whole trailing arm assembly
Cheers for any help
My question is
So what do i need ?
Master clyinder
prop valve
Cheers for any help
UKDM/EDM/CDM/AUDM ITRs are all 5x114.3 and use the 32mm spline. What year Civic are you putting it on?
Take the knuckle and trailing arm assemblies, brake lines, and ebrake cables. If you have an EK, I would take the master cylinder. If you have an EK hatch, most likely you won't need to change the prop valve, but in any case I would get it from an EK4 or EM1.
IronShogun
Oct 25, 2008 07:56 AM
93egboosted
Oct 20, 2008 02:48 PM
Rdriver
Apr 3, 2007 06:17 PM
