just curious...
Old Mar 25, 2008 | 09:55 PM
cleanej2's Avatar
Default just curious...
whats a safe psi setting for an ls as a daily driver
Old Mar 25, 2008 | 11:38 PM
JDM Lyfestyle's Avatar
Default Re: just curious... (cleanej2)
Psi isnt everything..search around and see what other people are doing and have a hp goal in mind.Also are you stock block or built?what turbo?theres more to it than just boost pressure.
Old Mar 26, 2008 | 07:44 AM
ChinQuee's Avatar
Default Re: just curious... (JDM Lyfestyle)
need to know more about car!
Old Mar 26, 2008 | 07:51 AM
1992Si's Avatar
Safe ?
Safe would be to leave it stock and buy a car that came with a turbo.
PSI depends and a lot of factures, we need more input.
Old Mar 26, 2008 | 07:55 AM
EkFG's Avatar
Guys i think he has a Stock ls. I would say if its a daily driver and a weekend worrier just set it at 4-6 psi nothing high.
but again it depends on what set-up you have, too many variables
Old Mar 26, 2008 | 07:57 AM
Schister66's Avatar
Man U FTW
I hate answering this question all the time.
PSI doesn't mean anything unless you're reaching into the upper limits of a turbo's efficiency range and have to worry about IATs spiking OR have to stay within the confines of a MAP sensor.
The safe limit for a stock B series like your LS is about 300whp give or take. The PSI needed to get there is basically irrelevant. For example, i've made 315whp on a stock block GSR for 2 seasons at 10.5psi (limited by the stock map) and had no problems on 91 octane. This summer on E85 (~105-106 octane) i'm shooting for 400+whp on the stock block at around 15psi on my S256. Its all in the tune...
Variables:
-turbo efficiency
-intercooler efficiency (both of these factor into IATs)
-MAP sensor
-static compression
-fuel grade used
Marc_Smith
Jan 29, 2010 02:49 PM
chrischaks
Apr 12, 2007 07:26 PM
95integraLS003
Sep 13, 2005 05:45 AM
hatchyboy89
Dec 16, 2004 06:22 PM
phear
May 7, 2002 03:41 PM
