Is my water pump bad?
Old Mar 25, 2008 | 08:39 PM
EKstacy's Avatar
Default Is my water pump bad?
I have had overheating issues for months on my 99 EM1. I replaced my busted overflow tank, replaced the thermostat, then it still overheated so I removed the thermostat. I also replaced the radiator cap. I am still running it without a thermostat and it seems to still run hot at red lights and drive throughs. Places where i have to stop it will overheat. Te fan is working fine also. I can open the cap and the water isnt moving. If i rev the engine up to about 3k rpm i can see it flowing water. Im thinking my problem is that its just not flowing enough at low RPM's.
So my question is: If your car is idling and you open your radiator cap, can you see the water moving without revving it up? I cant. Is that bad, or normal. Thanks for the help
Old Mar 25, 2008 | 08:44 PM
afstvx's Avatar
you probly have air bubles in there. open the bleeder skrew and turn the car on and turn the heater on so you can cycle the air bubles all the way out
Old Mar 25, 2008 | 09:26 PM
EKstacy's Avatar
Default Re: (afstvx)
ok, ill do that. I thought I could still bleed it by running it with the cap off and the heater on. Is your method more effective. Thanks
Modified by EKstacy at 10:53 PM 3/25/2008
Old Mar 25, 2008 | 09:34 PM
Ruben19's Avatar
my em1 dont have a bleeder screw.
i have to open the radiator cap, put a funel and run the engine with the heater on. when you done. make sure your lower radiator hose is warm. this will tell you if your thermostat opened.
Old Mar 25, 2008 | 09:54 PM
EKstacy's Avatar
Default Re: (Ruben19)
I got no thermostat in though. It should be flowing freely and its not. I was just wondering if it normally would be a noticeably flow in the radiator at idle?
90dxcrx
Apr 5, 2012 02:30 PM
hatchman88
May 30, 2009 05:50 PM
ownage
May 15, 2008 01:22 PM
forksports
Jan 17, 2004 09:32 AM
sherman19
Jan 30, 2003 05:36 AM
