axle comming out of trans! how to fix?
Old Mar 25, 2008 | 05:25 PM
incredteg3's Avatar
Default axle comming out of trans! how to fix?
ok so my axle has vibrated out of the trans on the passenger side (nonhalfshaft side) multiple times during burnouts and whatnot. So I was just wondering if anyone has found a solution to this problem. I am planing on just stretching out the cir clip when it goes back inthe trans this time.
Old Mar 25, 2008 | 05:39 PM
SpeedDreamz.com's Avatar
Default Re: axle comming out of trans! how to fix? (incredteg3)
What axles and diff?
Old Mar 25, 2008 | 05:46 PM
dookieK9's Avatar
i had that problem aslo. i just put a new clip on and it was fixed.
Old Mar 25, 2008 | 06:02 PM
IT'S ME DAVID's Avatar
NooB
Default Re: axle comming out of trans! how to fix? (dookieK9)
is this a ef.wrong axles is the answer...i had this problem i needed 90-93 axles i was using the older 89 axles..
Old Mar 26, 2008 | 07:59 PM
incredteg3's Avatar
Default Re: axle comming out of trans! how to fix? (IT'S ME DAVID)
nono this is a 95 LS integra. I figured I would just replace the clip like above just wondering if anyone else has a different idea. Its not a stock axle but I don't want to name names. I have a stock one in now but when my Quaife comes in I will be putting the aftermarket axle in at the same time. I just don't want to keep having the same problem.
stock diff for now, soon to be quaife. Think the quaife will help?
Old Mar 26, 2008 | 08:44 PM
redboost10's Avatar
no offense to dss at all, they are damn good axles but i know many have had problems with the passenger side axle popping out. you just gotta get it in the tranny all the way. what i did, along with rota/1992si was get a 2x4 and put it against the outter axle spindle and just get rough with it
Old Mar 27, 2008 | 04:49 AM
fmfkid250's Avatar
Default Re: axle comming out of trans! how to fix? (redboost10)
I wasted a Pass side DSS axle and striped a spool when it poped.
I dont know. I am going to send it back and they arew going to throw a new end on it for $250 this is the DSS stage 3's
Old Mar 27, 2008 | 06:47 AM
incredteg3's Avatar
Default Re: axle comming out of trans! how to fix? (fmfkid250)
interesting.. this isn't a DSS but I am sure it was installed correctly. Oh and they should replace you end for free if u put it in correctly.
Old Mar 27, 2008 | 07:34 AM
SPOOLINmatt's Avatar
i always get the tranny side in and use the outer joint as a slide hammer to ram that sucker in there. This has happened to me only once, and never again.
Old Mar 27, 2008 | 07:50 AM
1992Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">no offense to dss at all, they are damn good axles but i know many have had problems with the passenger side axle popping out. you just gotta get it in the tranny all the way. what i did, along with rota/1992si was get a 2x4 and put it against the outter axle spindle and just get rough with it</TD></TR></TABLE>
Another tip with this side axle is to make sure the shaft is in the best alignment angle with the diff. As straight as possible, may be put a jack under the LCA and raise it up to help the alxe get the best angle. Then use the 2X4 block and a 5-7lb sledge hammer. It never popped out again.
Old Mar 27, 2008 | 08:25 AM
fmfkid250's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incredteg3 &raquo;</TD></TR><TR><TD CLASS="quote">interesting.. this isn't a DSS but I am sure it was installed correctly. Oh and they should replace you end for free if u put it in correctly. </TD></TR></TABLE>
Mine was in there without a doubt I had about 12 passes on it and it was fine. Then one pass It almost sent me into a wall.
It could have been a mixture of the 2 the spool and the axles. but it was not the installation!
Modified by fmfkid250 at 6:17 PM 3/27/2008
Old Apr 1, 2008 | 07:28 AM
Coreymdean's Avatar
my passenger side axle can wobble in the trans fairly decent. havent had a dial indicater on it but it makes me nervous. pull diff out, and it looks flawless. DSS axles b16 trans anyone notice this?
Old Apr 1, 2008 | 07:56 AM
1992Si's Avatar
Default Re: axle comming out of trans! how to fix? (Coreymdean)
Call DSS and ask the experts.
Old Apr 1, 2008 | 08:54 AM
Coreymdean's Avatar
Default Re: axle comming out of trans! how to fix? (1992Si)
that was the plan, just wanted to see if anybody noticed the same thign
Old Apr 1, 2008 | 10:04 AM
FTP racing's Avatar
Yes it happened to me!...passenger side DSS stage 5...
Old Apr 1, 2008 | 10:13 AM
redboost10's Avatar
Default Re: axle comming out of trans! how to fix? (FTP racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coreymdean &raquo;</TD></TR><TR><TD CLASS="quote">my passenger side axle can wobble in the trans fairly decent. havent had a dial indicater on it but it makes me nervous. pull diff out, and it looks flawless. DSS axles b16 trans anyone notice this?
mine does that too, has the slightest bit of movement, i dont think its anything to worry about, its not leaking fluid and its not popping out.
Old Apr 2, 2008 | 05:26 AM
AR Fab's Avatar
On the Highend axle kits like the Mark Williams, I believe the new DSS kit and a few others the intermediate shaft gets bolted through the trans to the other axle hub to keep this from happening on the high HP cars..We drilled our Rob Moores just in case it happened, but it never did. Your install, the spool or the axle may not be your problem...You may just be shaking it out from wheel hop, torque steer, improper alignment, loose rack, bad ball joints, uneven tire roll out, left and right corner weights may be off etc.....it "should not" happen but its racing so it does.
Howard
Old Apr 2, 2008 | 06:16 PM
rodolfomercado's Avatar
Default Re: axle comming out of trans! how to fix? (AR Fab)
that happen to me to i put a bigger clip and remove the air from the axle boot,when they put the axle sometimes air goes inside the boot and pulls the axle out.always in the pass side...i have 5.9 dss axles
MUGEN_EG95
Jan 25, 2009 05:16 AM
dadrought6
Oct 18, 2008 11:19 AM
John.
Jul 28, 2006 10:56 AM
b18cEF9
Apr 21, 2004 01:22 PM
NikoZai
Jul 28, 2002 09:21 PM
